Page 3 of 6 FirstFirst 123456 LastLast
Results 51 to 75 of 145
  1. #51
    Active Member Sccar's Avatar
    Mar 2015
    East Texas
    Quote Originally Posted by Semper Fi View Post
    I got the "gold plugs" today and put them in. They fit great, look great, and work well. I am so glad to have gotten them today, my Spyder sat for 3 days and I couldn't ride it. The plugs are so much easier to tighten and remove, they have a head on each. One is a 15mm and the other is a 17 mm. In about 9000 miles, I am sure they will be very easy to remove.
    What are the part numbers for the Gold Plugs?
    Thank you
    2015 F3S SE6
    You don't stop riding because you get old, you get old because you stop riding
    2015 F3s , Orange/black
  2. #52
    Dec 2012
    Murphy, NC
    Default GOLD PLUGS
    www.goldplug.com. I love mine. Great investment!
    2020 F3 Ltd
    Spyderpops Bumpskid
  3. #53
    Canada
    I will remove the dimple plug next time i change my oil
  4. #54
    Mar 2013
    Marion, Arkansas
    Ok, I'm still confused. Could somebody list the 2 gold plugs part numbers to do an oil change. I have the dimple plugs in there now and I'm due for an oil change. Are they the MP-01 & MP-18 that is needed for the 1330 engine?
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
  5. #55
    That's what I just ordered for my RT...
    I'm chickening-out, and leaving the Dimples in my desk...
  6. #56
    Oct 2015
    Mifflinburg,PA
    That is the 2 I got my F3-S. I am sure they will work for you.
  7. #57
    Can I have your Dimples, I may need spares.
    PM me your mailing address... they're yours!
  8. #58
    Received, and
  9. #59
    May 2015
    United States
    Very good choice to get rid of them. You couldn't pay me enough to use dimple plugs.
    I guess I would take $1100 to use clutch cover plug and $2000 to use main engine plug.
    I'm very happy with the gold plug.
  10. #60
    May 2015
    United States
    FWIW, in a sad way, had they done a better method on the original design from Rotax / BRP the issue would not be a concern. Using a metal gasket to seal a drain in the modern era is for cost cutting. The drain plug itself and the mating surface should have been designed to use a Loc-O-Seal or an O ring. With that system snug plus is all it takes.
    The measured dimensions on the the Dimple Plug of over .070" is not bad. Also consider that the depth of the thinned portion is not to the bottom of the threaded area. So under torque, several threads of full strength are securing the drain plug.
    The entire breakage issue has happened and is real, no doubt.
    Unless the Dimple drain plugs are failing immediately on install and not during removal this would indicate a weak drain lug. If however the drain plug fails on removal, possibly the drain plug has bonded itself via the oil or galled to the aluminum, causing it to have a failure not related to tension while installing, but rather a torsional force and tension while being removed.
    My dimple failed on install as did spyderryder53
  11. #61
    Nov 2014
    White GA
    My 2 cents. I have a '15 RTS, the MP01 listed for the transmission does NOT fit my transmission. (I'll stop there).
  12. #62
    Mar 2013
    Marion, Arkansas
    Quote Originally Posted by hillrider View Post
    Why didn't the gold plug MP-01 not fit? Please explain. This is getting very confusing.
  13. #63
    Mar 2013
    Marion, Arkansas
    Quote Originally Posted by beefybudds View Post
    How do you know when the plug failed? Explain please..
  14. #64
    Active Member spyderryder53's Avatar
    Hanover CT
    Quote Originally Posted by Ex-Rocket View Post
    When i installed my plug i got it snug and then it seemed to loosen up, when i took it off it just spun .it broke off between the magnet and the base
    It could be beefybudds and l got defective plugs.
    Leon
    2022 marsala red RTL
    AND
    2014 RT S SE-6 COGNAC, 2010 RT 622 TRAILER TIMELESS BLACK
    BRP trailer hitch, Utopia back rest, Baja Ron sway bar , heim links. Elka stage 2 shocks front and rear.
    TricLed fender lights, saddlebag lights and mirror lights. LED headlights and fog lights, Wide vu mirrors.
    spyderpops LED bumpskid ,zippered cargo bag linings, Laser Alignment by Netzleys Tire, Stebal air horn
    stant gas cap,( Dimple oil plugs REMOVED ) JT dash mount.
    (Onboard) Lamonster Garage air compressor and intelliboost charger.
  15. #65
    May 2015
    United States
    Dealer installed mine and stated that as they started to tighten the plug it started to just spin.
    Yes the dealer could of over torqued but with multiple people having same issue I believe the plug was faulty.
  16. #66
    Nov 2014
    White GA
    MP01 was too large.
  17. #67
    That's the one that their locator suggests...
  18. #68
    Mar 2013
    Marion, Arkansas
    Went to website and for the 1330 engine I found the following plugs. MP-01 transmission plug, MP-02 oil reservoir plug and MP-18 1330 engine which this plug has the double O-rings. So I think that what is needed is the MP-02 & MP-18. I don't know what the transmission plug is. Others chime in their thoughts. Or is someone has ordered the gold plugs and know they fit correctly please tell us which one's you bought.
  19. #69
    May 2015
    United States
    I purchased the mp-01 and mp-18 for my 2014 RTS.
    It could be they engraved the plugs with the wrong model number.
    The mp-02 is even bigger than the mp-01
    mp-01 12mm
    mp-02 14mm
    Also there website search is not correct. There are not 3 drain plugs for the 1330 motor.
  20. #70
    Oct 2015
    Mifflinburg,PA
    Mouse over image to zoom
    Have one to sell? Sell now
    Details about Can Am Spyder Gold Plug Magnetic Oil Drain Plug Protection MP18 MP01 Engine 1330
    1 product rating
    Seller information
    goldplugcom (3364 )
    99.4% Positive feedback
    Follow this seller
    See other items
    Item Information
    Item condition:
    New
    Quantity:
    More than 10 available / 6 sold
    Price:
    US $37.99
    This is what I bought my plugs with last week.
  21. #71
    Oct 2015
    Mifflinburg,PA
    I am not the best at coping EBay but, now you know what to buy.
  22. #72
    Base upon what I read in their website: the MP-01 and MP-18 drain plugs; are the way to go!
  23. #73
    Nov 2014
    Rural Hall NC
    I have the MP-01 and it fit in my bike.
  24. #74
    Mar 2013
    Marion, Arkansas
    Ok, I guess its the MP-01 & MP-18 that most people say will fit the 1330 engine. I will order today
  25. #75
    Very Active Member zuni's Avatar
    Mar 2014
    JAX FL
    And why not this one from a SL Vendor? http://store.valueaccessories.net/Ma...rainPlugs.aspx at a whopping $6.
    CJ JAX
