Results 1 to 12 of 12
Thread: New Here
    Very Active Member Zip's Avatar
    Sep 2016
    LI NY
    Default New Here
    First I would like to say hello. I just purchased a 2011 RTS with the touring package. I will pick it up later this week.
    I have been reading the do's and don'ts and have a question.
    My bike has manual shift A) do I shift at the same recommended RPM (around 5000) ?
    And what about downshifting? Clutch and stop then down shift or down shift through the gears then stop? If the latter how will RPM come into play?
    Thanks in advance
    Jeff
    2010 RTSM5 , stock Stock Silver
    Both of mine have been "ESSIEs", so I can't answer your shifting question ...
    ...But LOTS of folks in here can!
    Active Member Grayfox's Avatar
    Nov 2012
    Advance n. c.
    I have a 2012 rts sm5. I shift up around 4000 rpm and down by what speed I am at. From 5th to 4th say around 40mph and so on. Hope this helps.
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    My experience with manual motorcycle transmissions is it's a lot easier to downshift as you are slowing down, rather than doing it after you have come to a stop, plus if you need to accelerate out of harms way or if the light changes you aren't in the wrong gear. Most sequential transmissions aren't happy going from top gear to first gear while stopped.
    Bob S
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default TIME
    TIME WILL TELL YOU WHEN TO SHIFT......
    it's all about comfort... if you are out for a nice smooth ride, you'll find yourself shifting at low RPMs, if you get aggressive, the RPMs will fall in place at a higher level... if you try to ride the way OTHER PEOPLE tell you, it will take you far longer to get the 'knack' on how your comfort zone is....
    ride safely and enjoy....
    Dan P
    SPYD3R
    and on your RT. The 998 engine likes to be shifted between 5000 and 5500. You will find the sweet spot on yours. For downshifts, I used to use 3500 going back from 5, 4, 3, and 2. I would use about 2500 for 2 to 1. Most of the time, braking will slow you down before the rpms. Just hold the clutch in and click the downshifts until you roll to a stop.
    Very Active Member Eagle1's Avatar
    Nov 2013
    Lutz, fl
    I had a 2010 rt standard shift and would shift at or above 4500 rpm and would down shift as I was showing down. It likes the higher rpms.
    Ryde as if your life depends on it,
    because it does !! Ryde Safe!
    Vietnam 67-69
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    with what akspyderman just said. Those numbers are a very good place to start. But as you ride more and gain a little experience , your bike will help you know when you need to shift for different riding situations. If you've already read the "DO's and Don'ts" thread, you already know that the object is to keep the 998 engine in that 5000 rpm range - give or take.
    You'll love that new bike of yours. Enjoy!
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Oct 2013
    rome new york
    Have 13 sm5
    5000-6000 rpm
    Very Active Member Ron2andia's Avatar
    Jun 2012
    Phila
    Live, Love, and Ride! God Bless!
    Very Active Member Tango's Avatar
    Apr 2012
    Florida
    Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
    2020 Petrol Blue Metallic RTL
    Vermont
    and
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
