using heated clothing items
has anyone safely used heated jackets, or socks, or handlegrips, etc. on a 2008 rs and not compromised battery power.
heated clothing
I use a 90 watt First Gear jacket and 30 watt gloves without problems. I do keep my bile on a battery tender almost year round. Only time it's not on a tender is on trips. Also use a fast inflator draws 10 amps for filling air mattresses when pulling the trailer, this is unbattery tender time.
All the great movements in the world began with a cup of coffee!
2018 F3-T
My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
I have Gerbing 12v gloves and Jacket with my 2009 GS and had no issues at all
Where can you get one?
Harrington, Australia
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
Where did you make the hookup direct to the battery- my 12 volt harness is too short.
heated gear
using heated gloves ( Gyde by Gerbing ) on my 09 GS wire to the battery and lead coming out from under seat works great hands are toasty warm
Improvise, Adapt, Overcome, Semper Fi
2020 RT
Limited heated seats
removable back rest & rack
XK Glow light
Paint with light painted panels
(Gone but not forgotten ) 2009 RS SE5
SpyderLovers Sponsor
The 2013 + models mount the battery in the Front and the standard 2 ft. power connection supplied with the Heat Troller is too short for these Spyders. There is a 5 ft. extension (Plug & Play) cable available for $22.50 to resolve this issue.
I am using a jacket liner and gloves for my wife and myself on a 2012 RTL. As long as I am moving there is enough juice to keep the battery up,slow speed in town it would probably not keep up. If the volts get to low I will turn my jacket off for awhile.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
I don't think you'll ever have a problem. All of the well made systems today use Pulse technology. The garment flows current in pulses a percentage of the time. So if you have your 90w jacket liner set at 20% (Which is very common) then you're only flowing current 20% of the time making your jacket an 18w draw. Very efficient. Only at 100% on the Heat Troller will your 90w Jacket Liner draw 90w.
We do....
We ryde double up with heated liners and heated gloves with no problems. Things to consider however are additional electrics you may have. I do not have any extra draws on the system. The 998 engine has a 650 watt output from the stator. The 1330 engine has 1200 watt output from it's alternator...
2012 RS sm5
Sorry mate but I have to ask....why do you need these when you live in San Diego?:-)
We are about 20 minutes from the snow and the mountains at 6000 feet in winter are cold for a warm blooded boy from warm climates...lol
2012 RS sm5
