Page 1 of 6 12345 ... LastLast
Results 1 to 25 of 127
    Active Member ITWorkerBee's Avatar
    Jun 2010
    Corrales, NM
    Default Valvoline™ 4-Stroke Motorcycle Full Synthetic 10W-40 Motor Oil
    Does anybody have experience with this oil? It rates great, but not sure about the 4 stroke aspect as Im running a 2014 rss se?
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Quote Originally Posted by ITWorkerBee View Post
    Used it all the time on my 2012 RTS sm5 no problems ,sold the bike at 56000 ,you can get a good deal at Walmart .com ,6 quarts box ,it has to be jaso MA 2
    Sep 2013
    Harper, Texas
    4 stroke means the piston does four strokes to complete the power cycle (intake, compression, combustion, and exhaust), all Spyders have four stroke engines.
    Default THIS VALVOLINE OIL
    I really like it ......I've read tests that show it has the 2nd LEAST amount of Molybdenum in the oil ( Amsoil has the least ). Moly is BAD for WET clutches ( and we have those )....... Also this Valvoline is Jaso Ma-2 rated and few oils have a rating this high .................... BRP's oil doesn't ( to the best of my knowledge )...................Mike
    Feb 2012
    Spring City,Utah
    Very good oil and currently on sale for $39.95/6pack on Walmart.com
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Default Good one...!!
    Up there with the top brands of oils. Most any oil meeting the specifications listed in your manual will do well in the spyder rotax engine. There are quite a few out there its just a preference or price decission....
    Jun 2010
    Corrales, NM
    Thanks everyone for the positive comments... Walmart here I come since it's 54 plus on amazon. Now the rings and filters
    Sep 2013
    Houston
    Its a great oil for the 998s.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi Mike,
    Re: this Valvoline is Jaso Ma-2 rated
    Just to have a 'look-see' I went to Amazon and found this:
    https://www.amazon.com/Valvoline-VV7.../dp/B00DJ4FGMQ
    I could not find any info on it being Jaso Ma-2 rated. Do you know if this item is rated as you mentioned?
    It is listed as VV-740 as a Valvoline part number.
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by JerryB View Post
    Hi Mike,
    Jerry Baumchen
    yes
    http://content.valvoline.com/pdf/4_s...motorcycle.pdf
    but this is not the full synthetic. But the full synthetic is rated also.
    http://content.valvoline.com/pdf/4_stroke_synthetic.pdf
    David
    Vermont
    p
    I am using the "Valvoline Motorcycle oil 4T Stroke "Full synthetic" 10w-40 (SAE) in my 2014RTS-SE6.
    I switched to this oil last year. Also, I am going to use the same oil for all of my spyder oil changes. It has Superior Wet Clutch protection.
    It's formulated for the specific needs of motorcycles, including high temperature , high RPM'S and wet clutch systems.
    Synthetic formula maximizes power and acceleration, Outstanding wet clutch protection for maximum power transfer and smooth shifting.
    Excellent wear & corrosion protection to help keep engine performing its best.
    Added protection against harmful deposits that can decrease engine performance.
    Exceeds API SERVICES: SJ/SG/SF, JASO MA2
    Deanna
    Last edited by Deanna777; 03-04-2017 at 02:34 PM. Reason: Updated post on 3/4/2017 @ 2:34
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Hi Mike,
    Jerry Baumchen
    Nope Jerry , that is their DINO OIL , the Full Synthetic is in a SILVER container and says 4 T -stroke ...most stores don't carry it..... you have to order it on-line ( in a SIX PACK ) and have it shipped free to your local store or if you buy enough they will ship to your house for free .....read the fine print for that ....... Mike
    Default THIS INFO
    Quote Originally Posted by Warlock View Post
    yes
    David
    Good, But not the BEST info on the Valvoline ..... it doesn't state how LOW the Molyibendium is ........only Amsoil is lower .....................just sayin, Mike
    Oct 2011
    Magnolia, Ms
    He wanted to know if it was JASO Ma-2 rated. I can get more info if needed. It is rated in the regular oil base and also in the synthetic
    David
    Dec 2012
    Morrton,Il.
    I have run it in a Yamaha FZ1 it was much better on the clutch than factory oil and I will run it when the BRP extended warranty runs out.
    Vermont
    I have bought the" Valvoline Motorcycle Oil, Full synthetic 4T Stroke, 10w- 40 in the Silver bottle". ( Superior Wet Clutch Protection) I bought 2 more bottles yesterday. Yes, it is there. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Jun 2010
    Corrales, NM
    Found it at AutoZone for (on sale thru today) for 9.97 a qt, or at walmart for 8.47 per qt. So it is out there.
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    I buy it at our local Wal-Mart for $8.47 a quart. About $10.50 a quart at AutoZone.
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Feb 2012
    Spring City,Utah
    Order it online in the 6 pack and pay $6.65 a quart.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Jun 2010
    Corrales, NM
    With Amazon?
    Sep 2013
    Houston
    Quote Originally Posted by redrt View Post
    Why would you wait until the warranty runs out? This oil meets ALL of the BRP specs for the oil. Its fully compatible with your warranty. This is the oil we use for all 998 oil changes. Very good product and far superior to the XPS oil.
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    You can get a 6 pack on Canadian Amazon for $297CAD. !!!!!!!
    Talk about getting screwed.
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Feb 2012
    Spring City,Utah
    With Amazon?
    No from Walmart.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    May 2013
    Indiana
    In a 6 pack from Walmart.com it's$39.95/ $6.66/qt. Need $50.00 to get free shipping.
    2021 Marsala Red Metallic RT Limited
    Feb 2012
    Spring City,Utah
    actually you can get in store pick up for free at any amount.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
