Results 1 to 4 of 4
Thread: Blinking signal
    Active Member ITWorkerBee's Avatar
    Jun 2010
    Corrales, NM
    Default Blinking signal
    Yesterday the right turn signal did not come on in reverse, but the signal was working. Since it was late/hot thought would deal with in am. Today it was working, and as it warmed up it stopped again. Must be a loose wire in the console area? How hard is it to get to those connections or just take it to stealership?
    RSS SE5 2014
    Jun 2010
    Las Vegas
    If you have an extended warranty your cost would be $50 and to me that would be worth the trip to a dealer.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default Depends....
    If you pop out the inst cluster you can get to all the wiring. That would be for the fronts for the rears you need to remove the fender pan... might test the bulbs first...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Dec 2016
    Cocoa Florida
    Default Same issue any updates
    I just pickup a 2013 yesterday and have the same issue, hazards works all lights flash, however the right turn signal doesn't work any updates?
