Engine downshift as a brake
Please tell me if I a) should or b) shouldn't use downshifting the engine along with the brake to slow/stop my Spyder. This is NOT a quiz. Everyone gets an 'A'.
Ryde, eat, sleep... Repeat
Ryde, eat, sleep.... repeat
2019 Spyder RT Limited Pearl White/Dark
LaMonster drink holder with X-Grip
LaMonster Belt Dampener
Lamonster USB cable with extension
Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
Coming from the TWO wheel world I continue to Downshift
AJ
2014 RT-S
Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
DOWNSHIFTING
I also downshift to save wear and tear on my brakes.
2020 F3 Ltd
Spyderpops Bumpskid
Spyderpops Brake/Run/Turn Signal LED's
Lamonster Garage LED Fog Lights and Headlights
2013 ST-S retired 1/9/16 at 25,061 miles
2015 F3S sold at 77,565 miles.
I downshift but I don't have a choice.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Ozzie Ozzie Ozzie
Sure you can, if you want to...... &/or if you like being in control, or in the 'right' gear to ensure you have 'proper control' of your Spyder at all times/off any situation - even if you have an SE Spyder!!
Your choice really, altho you did give us the choice of a) or b) responses & then say everyone gets an A, so I guess you'd really already made up your mind!
I let the engine slow me down along with downshifting. I do keep an eye on the mirrors and tap the brakes if someone is close to me.
I always down shift to help slow down.....just feels like the right thing to do with an SM5...
2021 RT Limited
Six of one, Half Dozen of the other.
No perfect answer.
Me: I let the engine shift down automatically (SE5 and SE6). If I need to "kick it," I shift down one and "hit it."
I've ridden 2 wheels for the past 1/2 century, and I've always, always used downshifting for slowing me down prior to stopping (this of course when conditions permitted) and I'm not about to stop now. That's what transmissions are for....decelerating as well as accelerating. That's why 18 wheelers have jakebreaks. They use the engine to SLOW them down, as do I.
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
Ozzie Ozzie Ozzie
Pragmatic Member
Engine braking is commonly used in motorcycles. Those of us who have been riding for years have always done it. It doesn't hurt the engine or tranny as long as it's done properly, and does help improve stopping and brake longevity. The key of course, is being aware of speed and RPM before downshifting, and then downshifting into the right gear.
As someone posted awhile back on a similar thread, and Bob Denman copied and pasted onto this one, it's cheaper to replace brake pads then it is to replace a transmission. However, if done properly you can engine brake without harming the engine or tranny.
Pam
- 2015 RT-S Special Series / Red & Black
- Baja Ron Sway Bar
- Utopia Backrest
- F4 Customs tall and wide vented windshield
- Stebel Super Loud Air Horn
- Baker Built Air Wings
- LaMonster Highway Pegs
- SpyderPops Exhaust Block Off Plate
- SpyderPops KOTT Grill
- SpyderPops Belt Guard
- Cat Bypass
- Laser Alignment by Squared Away
- TricLED Fender Lights
- General Altimax RT43 rear tire
- Dual flag holder
- Mud Flap
- A$$hole seeking missile system
BRAKES ....VS......TRANSMISSIONS & CLUTHCHES ETC
Let me play Devil's Advocate here for a moment...
I would rather put the load on the braking system, than on the drivetrain.
Brake pads are much cheaper to replace than drive-belts or transmission and clutch pieces...
Over 68,000 posts and this is by far and away the most sensible thing Bob has ever said.... Race car / mtc. driver's use their transmissions to BRAKE ......... But They don't pay to repair them...... and I'm an aggressive driver, and I do downshift, but only to be in a gear that gives me maximum acceleration coming out of the curve...My downshifts do not slow me down..... Play Joe racer if you want, but be prepared to pay for a tranny or clutch repair Bill $$$$$$....... Mike
Pragmatic Member
That's because he copied it from you on an earlier thread
Pam
- Baja Ron Sway Bar
- Utopia Backrest
- Cat Bypass
- Dual flag holder
- Mud Flap
I've always downshifted to slow down, you will use more clutch slipping the clutch from a stop than you will ever use downshifting, that's just let it out and it's locked, same with the belt one constant pressure holding back the bike not 115 hp trying to get up to the speed limit or more, also the trans if it can't handle a little downshift with help from brakes it shouldn't be in this bike it will get a lot more abuse taking off than it ever will downshifting. Even the owners manual in my wife's car says downshift when going down hill. ( I had to point that out to her )
They do down/shift themselves if left to there own but then-----
"To be shifty or shiftless, that is the question"? I see nothing in the owners manual that states one way or
the other. "So what difference does it make"?
The more post's I read the more confusing the world becomes.
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
SpyderLovers Sponsor
Sorry Bob. This is a myth. Though I must say, a long cherished and well rehearsed one.
Your gears will far outlast many other engine components. Not a problem. Seriously. Have you ever heard of someone wearing out transmission gears? I've seen them chipped or otherwise damaged from abuse. But more specific. Have you heard anyone here complaining about worn out transmission gears? Clutches and drive belts (as mentioned by another poster) take a great deal more abuse from acceleration than they ever will from proper downshifting.
Not only will you not be wearing your gears out. But putting the load through the engine (correctly) gives you more control than manual braking alone (though ABS does add a bit of caveat to this aspect). Of course you will save in maintenance costs, which is another plus.
In some circumstances you will keep from overheating your brakes and they will still give you great stopping power if needed. As in a long downhill run or towing, hauling heavy loads.
Always use compression braking. It will make you a safer rider and save you money at the same time.
I have my answer. I had always used downshifts with my VTX 1800 and I wanted to be sure I wasn't doing irreparable damage to my byke. (Note the use the "y"). I do like the fact that there are varied examples of advice. That way I can decide with a lot of information. Thanks.
RS-S
SM5 down shift and brake same time, as when I rode a motorcycle.
If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
Overheating brakes?!?
I live in the mountains, and haven't haven't felt a set of brakes heat up since 1972 !
I'm also existing in a pretty unique place: The traffic density is virtually nil!
Probably isn't going to happen much with a Spyder, I suppose. More likely with a bus or heavy truck. With the Spyder, more likely with organic than sintered pads. But I still think you could probably get the brakes pretty hot under the right circumstances. If you did, then when you really needed them for a panic stop they might not give you what you needed.
Long shot? Maybe. But good gearing/braking habits are a good thing to have. Even if you never need them. I just hate to see someone not use compression braking because they are worried about wearing out their transmission.
Plus 1 and if you downshift too early and the rear wheels skids as a result you can make it harder to control. Back when I was roadracing if I dropped down a gear too soon the rear wheel would hop and I'd lose traction.
Have to agree...
having worked on many a motorcycle transmission in my time I have never seen damage from up or down shifting with loads. I have always used the engine to slow down and being in the proper gear has saved my, and the wife's, butt many times. There will come a time when you will realize that you will not be able to stop in time but if you power through you will make it . You better be in the right gear to do this...don't ask, I have fingernail scars which remind me . The fact I have a manual and was able to slip the clutch made a world of difference. There are courses to help with this kind of driving and well worth it...
2012 RS sm5
I use engine braking to slow down for curves where I don't need brakes, and sometimes two up I use both engine braking AND brakes to slow down in a hurry.
JLohPhotos
