Page 2 of 2 FirstFirst 12
Results 26 to 45 of 45
  1. #26
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Just installed this one today.
    https://www.walmart.com/ip/215-60R15...Tires/52943290
    David
  2. #27
    Greenville Tx
    I just installed the Yokohama sdrive last week on my 13 RT! Has anyone been running with this tire and had good or bad results??
  3. #28
    May 2014
    Benson, NY
    Default Love it
    I have 8,000 mi. on mine and it is maybe a little more than 1/2 worn out. I will replace it with another one. I run 22 lbs in it and 40 lb. in my air bag. Seems to be the sweet spot for us.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
  4. #29
    Active Member ingramsail's Avatar
    Aug 2012
    Oklahoma City, Okla.
    Just replaced the S drive today, had 18533 miles on it . Replacement is also and S drive, happy with the way it handles.
  5. #30
    Nov 2014
    Rural Hall NC
    Quote Originally Posted by rtlister View Post
    I just bought the Kumho Esctra AST tire and got it yesterday ...supposed to have it installed tomorrow on the rear of my 2014 RTL. One of the Can Am dealers in my area that I called and asked if they would install the Kumho tire said they strongly recommended that I not use that tire. The dealership service guy told me he has a brand new one (Esctra AST) sitting on his office floor now that he just took off a Spyder. He said the owner said that it was sliding all over the place in the rain ...that the Kenda was a soft tire for that reason.
    On the other hand, I've read several good reviews from Spyder owners ...but I am wondering how many have ridden it in the rain.
    So...does anyone here have any experience with the Kumho Ecstra AST in the rain? It is a much stiffer tire and I expect it will last a lot longer than the Kenda (I certainly hope so) ...but just wondering about the rain?
    Suppose to have my Kumho mounted tomorrow at another dealership that is fine with it.
    I have the Kumho and just rode 100 miles home in the rain and the wind from Maggie Valley. Didn't matter what speed I was going, 60 or 80, the rear was planted on the road. No problems with the Kumho in the rain.
  6. #31
    Feb 2015
    McLain, MS..
    ............The Stealers only sell CRAPENDA'S .....so what do you think He's going to tell you ........ " All tires can & will HYDROPLANE " given the right conditions..... Mike
    I pulled my Kuhmo after about 11,000 miles as it was down to about 1/3 tread and I was getting pure scared of it in the rain...I rode from Mississippi to Connecticut and back late last year with that tropical storm skirting the coast and between going up and coming back did about 900 miserable miles on the slab in the rain...It was hydroplaning at times at 35 mph...Comparing it to the factory Kenda it hydroplaned worse at equal speeds and tread depth...I am not yet convinced all tires will hydroplane that bad...I have that General Altima tire on it now and figure about 10,000 miles from now I will know.......
  7. #32
    Kennesaw, GA (Atlanta Area)
    Quote Originally Posted by Bam Bam and Pebbles View Post
    I too have the Kumho for the rear....what pressure are you running? My tire must be over inflated because when it is wet out there my back end cuts loose at every start up
  8. #33
    Active Member rtlister's Avatar
    Feb 2015
    Anderson, SC
    When I originally started this thread, it was just before getting the Kumho Ecstra AST. I had a little anxiety about it since some had frowned on the "car tire" so I was hoping I wasn't making a mistake changing to a car tire.
    Now I've put over a 1000 miles on it (with some wet pavement included). I made the right choice...it handles great wet or dry! I don't know how the millage will turn out, but it couldn't be less than the two previous Kendas and I fully expect it will go way beyond the millage I got on the Kendas (rear). They were terrible.
    And another plus: the Kumho was around $90 (shipping included)... Kenda would have been $40 more.
    One other note, while searching for the Kumho Ecstra AST, one online tire company told me that Kumho has discontinued that tire. I found one however at Tirerack.com. That's where I got mine but I think it was one of the last ones they had.
    So far, I am very pleased with the tire! And I'm really glad to get away from Kenda (rear tire...the fronts do ok for me). Happy riding!
    Sent from my SCH-I545 using Tapatalk
  9. #34
    Default HYDROPLANING
    Quote Originally Posted by DC1 View Post
    I don't know if you have ever read my THREADS concerning HYDROPLANING ..... You don't mention what PSI you had in your Kumho, and this is very important. Lots of folks here have switched to CAR tires and used the PSI ( 28 ) of the Kenda's - - - BIG mis-take....... The Spyder doesn't weigh 4000 lbs., but the Kumho can easily handle that weight. The Kumho and/or any CAR tire will perform MUCH better ( especially in WET conditions ) at about 21lbs ( cold ) PSI. ....... On this and other Forums you will get lots of opinions on this subject, I have " Testified in COURT " about it. So I'm actually considered an Expert.......PS the Altimax is a good choice, I have been recommending it for a couple of years. Run it at 21 lbs PSI and it will perform at it's best on your Spyder .............Mike
  10. #35
    Aug 2016
    Australia
    Running car tyres on this 2010 RS , using 18 PSI front at the moment ,and 28 in the rear which I now think is too much.
    Racing against a HD V-Rod the other night the back just smoked up and let the V-Rod get a half bike length on me which I couldnt pull back.
    I'm guessing dropping to 21 PSI would improve traction.
    Considering when I run my RWD 1971 V8 Ford at the dragstrip I drop the rears to 21Psi for traction I'm sure 21PSI on a much lighter Spyder will be fine.
  11. #36
    Vermont
    Quote Originally Posted by finless View Post
    Picture not working for me either. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  12. #37
    Jun 2013
    Hanover,pa
    My dealer refuses to put a car tire on
    Sent from my SM-G928V using Tapatalk
  13. #38
    Jun 2013
    Hanover,pa
    I have a 2012 RTS my dealer refuses to put car tires on he said they are too slippery. I had 1850 on my first back tire before I had to replace it so I will stick with the original.
  14. #39
    Default SLIPPERY TIRES - WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAT
    Quote Originally Posted by Skipnuss View Post
    Unfortunately for you - your dealer isn't very knowledgeable about tires ......... and that may only be the TIP of the iceberg ........... I'm assuming the " 1850 " was meant to be 18,500, if so that has to the All time record for a CRAPENDA used on the Rear of an RT .........were you riding on the CORD ????? ..... Mike
  15. #40
    Jun 2013
    Hanover,pa
    Actually the tire was still in half way reasonable shape, but getting thin in center. Yes I meant 18500.
  16. #41
    Very Active Member dlby's Avatar
    Nov 2014
    Indiana
    S Drive is great
    Im sure lots of tyres are good!
    But the S drive is more than a bike or car tyre.
    It is a sports tyre.
    Luv it
    I love R&R put another dime in the jukebox baby!
  17. #42
    Nov 2014
    Rural Hall NC
    Quote Originally Posted by Brian Kay View Post
    At the time I was riding in the rain, it was 26. I have since lowered it to 22. I figure the cooler weather will lower it a little bit more for me.
  18. #43
    Nov 2014
    Rural Hall NC
    Hey!!!! I am now a Very Active Member. I guess 500 posts must be the cutoff point. WOW, only 150,000 more posts and I can catch up to Bob!
  19. #44
    Central Oklahoma
    Default Kumho Ecsta AST KU25 All-Season Tire - 225/50R15 91H
    Kumho Ecsta AST KU25 All-Season Tire - 225/50R15 91H ordered from Amazon and had it 2 days later.
    2020 RT Limited , Petrol Metallic Dark
  20. #45
    Nov 2014
    Indiana
    S drive
    Yeah babey
