Page 1 of 2 12 LastLast
Results 1 to 25 of 33
    Active Member ES44AC's Avatar
    Sep 2015
    Mocksville,NC
    Default What is the easiest way to clean rear wheel on 2015 RTS?
    What is the easiest way you have found to clean up the rear wheel? My hand doesn't fit very well, due to the tight spaces.
    2021 RTL Marsala Dark Edition 4.13.2021
    Lamonster Riser
    Spyder Extras Docking station
    Zumo XT (my own Plug & Play cable)
    WrapMySpyder Carbon fiber partial kit.
    Baja Ron ultra performance sway bar and end links
    2015 RTS SM6 Intense Red
    born on date 3/2015 (mine on 9/12/15)
    Sold on 4.13.2021 33k of fun.
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by ES44AC View Post
    Power washer after spraying with most cleaners does wonders
    Active Member fjray's Avatar
    Aug 2015
    central oregon
    Ride in the rain
    Have somebody else clean it!
    Very Active Member Deer Slayer's Avatar
    Mar 2015
    Advance, NC
    I use an old wash mitt the cotton type on a piece of broom handle on me RS-S.
    If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    Out of sight...out of mind
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Old fashioned way wash mit just keep rolling bike ahead you will figure it out
    Sep 2015
    Chilliwack, BC. Canada
    If only it were that easy. That's like pounding your head on a brick wall!
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Default TRY THIS
    Spray Simple green cleaner let it sit for 5 minutes or so, use a toilet brush to scrub , then wrap same in an old rag, rub some more , rinse with hose, ..... I find if I leave the Spyder in neutral I can just move it by hand a bit at a time to get the entire wheel done ......Good Luck ........Mike
    Jul 2010
    Las Vegas, NV
    Default Easiest?
    Remove wheel, scrub. Rinse, install. Most thorough, gets it cleanest. 1 hour.
    next easiest, get a brush for wheels; looks like a Christmas tree. Jack up bike, scrub, turning wheel by hand. Bike in neutral, brake off, front wheels chocked. You lay beside it, bucket of soapy water , brush and hose. About 20 min per side.
    Several spray on hose off products out there. S100, wheel magic, merlins blood, armor all wheel cleaner. I've tried most of them, and they are ok if you don't look closely. If you do, you'll spend an hour detailing afterwards, and wish you would have just taken the thing off to begin with!! All depend on how clean is clean. Here, in 100 degrees, I do more quickies and try to keep after it. Once it cools off, deep cleaning resumes!!
    Joe Meyer
    Linden, CA
    Default Coin Op
    Coin op car wash
    Very Active Member garb55's Avatar
    Coolidge Arizona
    Quote Originally Posted by cptjam View Post
    I've tried that but I don't have enough hands
    Cause one hand always has a beer in it
    Now 2014 RT Limited Cognac
    Was 2008 GS SM5
    Don Garbarino
    Cup Holder
    GPS locking holder
    Mud flap
    Modified KNOTT grill
    Phone holder and charger
    Trailer hitch
    Dual air horn
    Auxiliary fuse box with relays
    Heated clothing controller
    volt/oil pressure gauge
    Sequential signals in mirror
    Tri Axis Handle bars
    Baja Ron anti sway bar/heim links
    shorty antenna
    And many more
    washington state
    A brush with handle like toilet bowl cleaner will help you reach the hard place. Good luck and have fun.
    2012 Spyder RT SE5 Brake pedal mod
    Jun 2014
    ny
    i use my power washer & min40 green but any wheel cleaner & power washer should do it
    Sep 2015
    Mocksville,NC
    Quote Originally Posted by Deer Slayer View Post
    That sounds like a great idea,thanks.
    Lamonster Riser
    Sep 2014
    USA
    I just found Maguire's wheel cleaner works really well on wheels.
    An if I want more I will use a wheel brush wooly wheel brush
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    Hire someone.
    Bob S
    Very Active Member Buggy's Avatar
    Ontario Canada
    This works great.
    2016 RT Ltd. , Pearl White
    Invalid Emails
    Jul 2014
    Rotonda West,FL
    can we jack up just the back wheel? using the shock?
    Sep 2014
    USA
    Quote Originally Posted by CapeSpyder View Post
    Not recommended. Use the frame to jack up
    Jun 2014
    ny
    Quote Originally Posted by Buggy View Post
    This works great.
    My proctologist recommended the same brush
    Quote Originally Posted by SPECTACUALR SPIDERMAN View Post
    Default YES ----- HOWEVER
    ....You need to use a piece of wood that is larger than bottom shock MOUNTING TABS .......I wouldn't use the shock it-self .............jmho.....Mike
    Very Active Member Ron2andia's Avatar
    Jun 2012
    Phila
    Quote Originally Posted by GOZFST View Post
    Hire someone.
    Sold!
    Live, Love, and Ride! God Bless!
    Jun 2012
    Phila
