Results 1 to 5 of 5
Thread: Protenza tires
    Invalid Emails
    Jul 2010
    1/2way tween STJames and Salem Mo
    Thumbs up Protenza tires
    I KNOW that somewhere on here is some info on these tires and what the air pressure should be for a 2010 RT. I just got em but they aren't on yet and need to know the air pressure so I don't get really nutsy with them.
    Contact Firefly... He had used a pair of them, and always seemed happy with the results.
    Default POTENZA'S
    Since they are CAR tires , they are stronger with stiffer sidewalls and more tread plies, so they will run flatter..... Personally I feel all car tires ( for front ) should be at about 17 lbs....( for rear about 20 psi + or - )......the more pressure you put in them the harsher the ride and the more likely they will HYDRO-PLANE .;....... Mike
    Sep 2016
    Alma,Arkansas
    Default Potenza tire pressure
    We have installed the bridgestone tire on 2 spyder both 2008 SME models. I have found that the best ride is with a pressure of 14-16 PSI.
    Working for me and the wife very well.
    Good Luck
    Invalid Emails
    Jul 2010
    Default Potenza tires
    THANK YOU to all the folks who answered this one!!! Greatly appreciated.
