2012 RT Leaking Battery
Hi all. I purchased a sealed battery from batteries plus to replace the original battery that was at least 5 years old and running at or below 12V in my 2012 RT SE5 However that battery started leaking the next day. They gave me a replacement Duracell Platinum and it seems to be working great. It cost less than the BRP battery. Has anyone used or has this battery in their spyder now. If so, is it a good battery to have in lieu of the OEM battery?
And for those who have never changed a battery on a 2012 and prior RT
Here is an overview of my battery removal (my first time doing it myself) Thanks again.
JW. Metro Atlanta. 2012 RT SE-5, TircLed mirror turn signals, run/turn saddlebag lights, ring of fire, and fender tip lights, ShowChrome backrest,chrome (wide) foot pegs, SpyderPops spyclops, A-arm LED's, JT's USB Port, Digital Voltmeter ( Ebay) and Performance Powersports Scoops.
I just put a Duracell in our 2012, we shall see together.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
What a coincidence had to change my battery bout a month ago on my 2012 RT.
2012 Spyder RT Limited Lava Bronze (Psalm 27:1;Luke 12:4,5)
Stop talking about it! My bike will hear you and then I'll have to change the battery in mine, too!
Myron Wooley
USMC 1975 - 1979
2nd Spyder: Pearl White 2016 Spyder RT Limited, purchased December 18, 2016 with 1 mile
First Spyder: Pearl White 2012 Spyder RT Limited, gone to a good home
Replacing 2012 battery
What size battery did you buy?
Did you have a choice between
a gel or conventional acid battery?
Thanks,
Bill
I think I am on the verge of replacing mine as well. I was also looking at the Batteries + as a source for a replacement. They show 3 batteries as replacements for my 2011 but none of them are "Platinum".
2016 RT-S Special Series
