Results 1 to 21 of 21
Thread: 1500 CC ???
    Active Member Doug's Avatar
    Jul 2013
    Brights Grove, Ontario, Canada
    Default 1500 CC ???
    Was just about to get on my spyder today when a chap came over to ask me questions, I thought, instead he proceeded to tell me that BRP are coming out with a 1500 cc engine, has anyone else herd this.
    2017 F3-S , circuit yellow
    Mar 2013
    Maumelle, AR
    I haven't. Did he say where he heard it?
    2020 RT Limited , Chalk
    Very Active Member BikerDoc's Avatar
    Clermont, Florida
    Rotax (owned by BRP) already has higher cc engines available.. They are just used for their other products , not Spyders and clearly will not be in 2017 product line already announced.. In the future - who knows??
    220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
    1330 to 1500 -- Not worth the effort IMO. Give us a 1800/6 similar to the wing and go from there.
    Mar 2012
    NJ
    The rotax 1503 triple makes 155hp NA and 260hp with a supercharger stock. Yes, either configuration would be a big improvement in power.
    Highly doubt they would ever make it to the Spyder though.
    Sent from my Nexus 6 using Tapatalk
    Default Relax...
    No 1500 cc engines at the moment....enjoy the 1330 cc...
    ​2012 RS sm5
    Quote Originally Posted by BikerDoc View Post
    I believe that those are currently being used in personal watercraft?
    And to that point...
    Quote Originally Posted by DrewNJ View Post
    You answered my question before I was done typing it?
    Are you a mind reader?
    (Mine's like a comic book; isn't it?)
    Seriously: there'd probably be a lot of re-tuning necessary to fatten-up the power delivery, and you'd lose some of that great peak horsepower along the way...
    Mar 2012
    NJ
    Obviously you might not see the same numbers, however, That's the beauty of forced induction. You could put the power anywhere you want. Guys push 300+hp easily and reliably on the water. Street would be even better/easier.
    The problem is direct drive vs. transmission.
    I actually believe that cost considerations would have any initial offering be a naturally aspirated version.
    Mar 2012
    NJ
    BRP's target spyder audience isn't into it though (performance). It's all about bags, lights, trailers, etc.
    The watercraft industry is completely different, being more performance driven. So, while it "could" be done, it likely won't. I think the best you'll see for quite some time may be a few improvements to the existing 1330.
    Active Member Grandpa Pete's Avatar
    Sep 2012
    Rockford, Minnesota
    As I've said before, put a drive shaft on the RT with the 1330, and it will be close to perfection
    Grandpa Pete
    Peter & Kim Pontinen
    2020 RTL Dark Marsala
    Active Member _..stiffler..'s Avatar
    Feb 2015
    NB Canada
    nobody right now to really compete with. so as a business stand point it wouldn't be good for them to come out with anything crazy for the spyder. when other companies start joining the 3 wheeler market and brp has competition then you will see power and performance grow.
    just my opinion.
    2011 RT Limited , White
    Apr 2015
    Green Bay, WI
    Current 1330 compression is 12:1 . That compression would need to be lowered to run anything over 6 psi or engine damage--head valve seats-etc will happen.... Plus the higher the RWHP the more other drive components need to be beefed up--it's endless--I need C16 fuel=$18/gal plus retarding the top rpm end timing by a few degrees with lower compression pistons--reinforced rods--heavy valve springs--to run 14-15 psi turbo boost on a 1298cc Suzuki engine---currently 343 rwhp with 212# torque=need to feather the throttle in 1st & 2nd gear==3rd is like being launched by a rubber band---did I mention a Robinson re-built transmission.==bring $$$$.
    Jet Ski can have high HP spinning a small propeller---not the same as a large wheel--torque stuff.
    Apr 2015
    Green Bay, WI
    Nov 2013
    Oro Valley Arizona
    So many rumors, so little time!
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Very Active Member Tango's Avatar
    Apr 2012
    Florida
    Not till 2019. In a redesigned RT. Tom
    Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
    2020 Petrol Blue Metallic RTL
    Sep 2013
    Johnson, Vermont
    I noticed the Can Am Maverick X3 has a Rotax 900 ACE engine putting out 154hp. Damn, why isn't that in a new RSS........oh that's right...BRP doesn't make those anymore. Well, then why isn't that engine in the new Daytona F3..........oh that's right BRP thinks just adding some cool graphics and colors adds performance.
    http://can-am.brp.com/off-road/maverick-x3.html
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    Erm...this Spyder rider is into performance and I'm sure I'm not the only one. However you don't necessarily need more CC for that.
    The 1330 does seem to be the wrong starting point for performance judging by its current figures.
    Now an RS Mark II with a supercharged 1500cc would be interesting:-)
    Jul 2010
    Las Vegas, NV
    Default Hmmmmm
    Quote Originally Posted by PistonBlown View Post
    YES! Make that!
    Joe Meyer
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    Don't even need to do that. Just get the 1330 built & tuned right! There are triples with LESS displacement in bikes that pump out 150hp all day long for f*#K sake....
    Chuck
    Feb 2015
    NB Canada
    Maverick X3 for example.
    900 with 157hp. Lol. Turbo'd of course.
    Sent on Note 5 in Taptalk
