Pragmatic Member
Looks good. Wouldn't mind having one myself. I'll look into it.
Thanks!
Pam
- 2015 RT-S Special Series / Red & Black
- Baja Ron Sway Bar
- Utopia Backrest
- F4 Customs tall and wide vented windshield
- Stebel Super Loud Air Horn
- Baker Built Air Wings
- LaMonster Highway Pegs
- SpyderPops Exhaust Block Off Plate
- SpyderPops KOTT Grill
- SpyderPops Belt Guard
- Cat Bypass
- Laser Alignment by Squared Away
- TricLED Fender Lights
- General Altimax RT43 rear tire
- Dual flag holder
- Mud Flap
- A$$hole seeking missile system
Let us know how it works...
i dont even use the radio. just think it looks better. turn on the weather
part to see if we will be dry or fubarred. irv
2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
and some little stuff. setback utopia backrest, baja ron
sway bar, oem adj. air deflectors, marlin gps compass,
lamonster fbb foot pegs[modified brackets], lamonts
vibration damper, rock guard, and side case stiffener kit,
. brp comfort seat. , fomozas and
altimax, magic mirror mts, and wide mirrors.
[joyce & irvin toms]
Antenna
Greetings from Idaho
2014 RT-S,
Barjaron swaybar, chome luggage rack, Ram Mount GPS, 12 volt dash outlet, spyderflap mudflap, Rivco flag mounts, drink2go and custom handlebar drink holders,Driver Backrest,Tri-Axis Handlebars, TRICLed turn signal lights. Custon Dynamic Magic Strobe Brake Modulator, Triple Dash Pouches, "Squared Away" Laser Alignment, Spyderpops Bumpskid, TricLed "Knightrider" LED
2014 RT , White (Mine) Cognac (wifes)
Ordered one and already have the shipment notice
2021 Sea To Sky, 2020 RTL
but our benefits don't?
Originally Posted by cyclekid58
Plus $5.00 shipping, might as well buy from a good sponsor and save .50 cents
Cruzr Joe
Cruzr Joe
I hope you're not saying other site sponsors are not good.
2018 F3 LIMITED
Originally Posted by trikermutha
This is what I got from Harvey
The antenna is a quick change out, using a 7mm open end wrench to get the old one out and then use blue/medium Locktite when you put the new one in. The grommet will slide over the antenna after you get it installed and I installed the adapter in the antenna first using the 3mm socket to tighten it all the way then screwed the assembly into the hole on the Spyder.
The grommet seems to be a little hard to get it snapped into place but if you push in the bottom first then you can use more force to push in the top. It really fits tight and flush. I installed 4 yesterday and everyone was very happy with it.,
So...you did not need to get to the underside of the tupperware ? Thanks !
Craig From Albany Oregon
My Bad ............. Did not know that value accessories was a sponsor. I looked at our sponsor list and now i know.
Cruzr Joe
More instructions I got off another site..Pretty Simple
SPYDER RT:
1. REMOVE THE OEM ANTENNA BY FIRST PULLING UP ON THE RUBBER BOOT AT THE BASE OF THE ANTENNA.
2. USING A SMALL LOCKING PLIERS GRIP THE BOTTOM BRASS PIECE ON THE ANTENNA AND TURN LEFT TO REMOVE.
3. CLEAN THE FLAT SURFACE AROUND THE THREADED HOLE WITH A CLEAN RAG AND RUBBING ALCOHOL AND LET DRY. SEE FIG. 1.
4. TAKE THE NEW RUBBER GROMMET FROM THE PACKAGE AND PUSH IT INTO THE HOLE ON THE BODY PANEL AS SHOWN IN FIG. 2.
5. REMOVE THE SET SCREW FROM THE PACKAGE AND CLEAN THE THREADS WITH RUBBING ALCOHOL. LET DRY.
6. PUT A SMALL DROP OF REMOVABLE THREAD LOCK ON THE THREAD NEAR THE END OPPOSITE OF THE HEX SOCKET.
7. INSTALL THE SET SCREW INTO THE ANTENNA MAST AND TIGHTEN WITH A 3MM ALLEN WRENCH. SEE FIG. 3.
8. PUT A SMALL DROP OF REMOVABLE THREAD LOCK ON THE EXPOSED THREADS OF THE SET SCREW.
9. CAREFULLY INSERT THE MAST THROUGH THE HOLE IN THE GROMMET AND THREAD IT INTO THE THREADS IN THE SPYDER. SEE FIG. 4. HAND TIGHTEN.
10. YOU MAY NEED TO SLIGHTLY ROTATE THE GROMMET AS YOU ALIGN THE SET SCREW WITH THE THREADS IN THE SPYDER.
Ordered an antenna yesterday along with an air horn. Order status is Awaiting fulfillment. Guess he ran out?
He will ship them out Tuesday he said. new shipment will be in Tuesday Morning
Cruzr Joe
Looks like I will have Mine Friday
So no word on F3T compatability?
The radio reception sucks so badly I'd be willing to try something new.
Thank you for letting me know!
Antenna
Cruzr Joe
Just another purchase option, I have never had any issue with anything from value accessories.
2014 RT-S,
Pragmatic Member
I just ordered one from SpyderPops. I don't ever listen to my radio (Not sure if it even works), but I just like the looks of this one better.
Thanks for the heads-up Joe.
Pam
- Baja Ron Sway Bar
- Utopia Backrest
- Cat Bypass
- Dual flag holder
- Mud Flap
Just got my order in today! The antenna was very simple to install and looks GREAT! No more problems with putting on the cover with the original long antenna. OH and no more ep ep horn, installed the WOLO Bad Boy Horn. It too was very easy and sounds AWESOME!!
Thanks so much SPYDERPOPS!!!
Pragmatic Member
I received mine today and will probably install it tomorrow. Looks fairly simple.
Thanks SpyderPops for another speedy fulfillment!
Pam
- Baja Ron Sway Bar
- Utopia Backrest
- Cat Bypass
- Dual flag holder
- Mud Flap
New antenna with better range and much more solid, Just got this from Spyderpops and it comes with a new style boot that won't fly off and works with half or full cover without breaking, what do you think, looks good don't it?
Several of us were at Spyderpops yesterday and had them installed, very solid and good range. I especially like the new "boot" that is nice and tight.
Cruzr Joe
I bought a replacement antenna from Walmart for about 9.00 and it works good, it comes with several fittings and you have to figure out which one to use, but I seen this on YouTube and it works.......
Originally Posted by akspyderman
We were in Juneae today. Beautiful place.
Pragmatic Member
Installed mine today, took about ten minutes with most of the time spent wrestling the factory antenna off.
I had to pull out the manual and learn how to change and set radio stations, as I haven't used the radio in the 15 months I've owned my .
It seems to work well, although I can't compare it to how well the stock antenna worked since I never used it. It certainly looks better though.
Pam
- Baja Ron Sway Bar
- Utopia Backrest
- Cat Bypass
- Dual flag holder
- Mud Flap
Haaaaa
Now, that was funny.
Did own: 2008, Red, SE5 - and 2010, Black, RT-S Premiere Edition Number 670
Now Own: 2014 Black RT-S SE6
