SPEAKERS-2014 ST-LIMITED
Cannot hear the music with stock speakers.
Is their any way to just change out the speakers without adding all the other stuff and get a better sound at 60-70 mph.
Thank You,
Justacruisin
SPEAKERS
Do you know what size they are ? ? ? ....... Mike
The front speakers on a ST are the same speakers used on the rear of a RT. Yes they suck. I replaced mine with Pioneer speakers that worked great for a while and now suck too. The biggest problem in finding a speaker that will fit is the depth. Most replacement speakers are too deep and will have to be shimmed out.
what size pioneer did you use? In your opinion why do you think the speakers sounded good but later horrible?
Speakers
I do not use the radio while I am riding, it is my time, but could you add bluetooth speakers and run the sound into the helmet?
Good Luck
A large windshield made the sound better for me. The wind had a big effect on the sound.
2017 F3 Limited
Not sure why they went bad. But cannot run any base at all anymore because of the distortion.
Sounds like they are not waterproof that will destroy a speaker in no time flat. Auto speakers are NOT waterproof, they are treated with a minor coating to make them somewhat water resistant but rain and dew will destroy them. Need to make sure there rated as waterproof or marine accepted. Any others will not last.
I installed sound systems in autos years ago and would run into this many times. So if there not marked as Marine approved or waterproof there NOT.
Question
What was the size of the speakers....
