Results 1 to 13 of 13
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Default Help who has had this problem
    Hard steering check eng lite on dynamic power steering indicator on who has this problem 2014 RT
    Very Active Member spyderCodes's Avatar
    Jan 2016
    PA
    Check your battery connections, the DPS consumes the bulk of the electrical power used by the Spyder.
    The Power of Logic.
    Start Thinking.
    Jul 2011
    Mitchell, Ontario, Canada
    Press Mode, Set and Turn Cancel buttons. All at the same time. Tell us what codes come up.
    May 2016
    Thank you I will try that
    Sent from my SM-T350 using Tapatalk
    May 2016
    OK can anyone explain this code P0562
    United States
    Spyder Diagnostic Codes - P0562
    System voltage Low
    Alternator defective
    or not connected
    Battery failure; an
    external battery charger
    may have been used.
    Damaged circuit wires or
    connection.
    Measure battery voltage with
    engine stopped (expected
    value: 11 to 13 volts).
    engine running (expected
    value: 13 to 14.7 volts).
    Check connections
    on voltage regulator.
    Check ground and positive
    connections on battery.
    Check ground on vehicle frame.
    Jan 2016
    PA
    You may want to download the free app spyderCodes, available at the Play Store or App Store.
    The Power of Logic.
    Start Thinking.
    May 2016
    Thank you
    Aug 2017
    Alberta
    Smile P0562
    Quote Originally Posted by Roadster Renovations View Post
    System voltage Low
    or not connected
    Battery failure; an
    may have been used.
    connection.
    Check connections
    Can anyone clarify, why connecting and external battery charger could cause this code?
    Battery failure; an
    may have been used.
    Two days ago I hooked up my battery tender. This morning, I disconnected it ( it has the quick plug and go type connector) and started the bike. The check engine light came on and I got the handle bar warning light. Checked and got the P0562 code. I checked voltage not running and it is 12.86. Running it is 14.26. Perfect I would say. I shut it off, restart and all is fine for about a minute, then it comes on again. Tried disconnecting battery for a bit, that didn't help. Any ideas? Thanks guys. Enjoy reading this forum. The operators manual covers charging, replacing and boosting, but no mention it will start throwing codes.
    Aug 2018
    Austin, TX
    Quote Originally Posted by spyderCodes View Post
    Sounds useful, but the app shows as $15.99 in the Apple App Store. Is this correct?
    Jul 2018
    Eastern Kentucky
    Quote Originally Posted by rocketman74 View Post
    This shows free to me
    Sorry, just noticed the part about apple
    Aug 2018
    Austin, TX
    Quote Originally Posted by Shadowkast View Post
    Interesting. Here is what it looks like in the iOS/Apple App Store...
    SpyderCodes now costs for Apple phones, but atm is still free for Android phones...
    But we have been told that the next upgrade means it will cost for Android phones too! However, that doesn't take away from the fact that it'll still be Cheap at twice the price! It is a very useful & handy app that can save you a lot of worry & dollars!
