Results 1 to 20 of 20
    Feb 2016
    France
    Default Digital display affected by heat
    Where I live in the north of France, this week the temperature has soared into the 30's, unusual for here, however I left my RT in the sunshine, when I switched on the digital display had 2 black bands top and bottom, as the display cooled down they disappeared, I know LCD can be affected by temperature but has anyone else had this problem.
    Alex
    2014 RT Std
    Floor and Highway Boards
    50$ GPS connected to oem loom
    Trunk & Frunk Liners and lights
    Frunk and dashboard power outlets
    Front supension LEDS
    Cup holders
    Glovebox light
    Turn signal LEDs in mirrors
    12 volt coffee maker
    Passenger hangrip muffs
    Ignition lock light
    Windscreen wiper/ baguette holder
    If I wasn't so cleverI wouldn't need to be so good looking.
    2014 RT , Black
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    Yes, had it happen to me once and others here have complained about this also.
    2018 RT LTD , Black
    Some folks will pull out the "warning card", for use as a shade for the display...
    A common occurrence when the temperature gets higher and the is left out in the sun.
    Jun 2014
    ny
    When you say 30's you do mean celsius?
    Very Active Member Deer Slayer's Avatar
    Mar 2015
    Advance, NC
    Default shade.
    I put my driving gloves over the display. You have to put them some place. Stops the lines. Ride on...
    If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
    Jul 2016
    Braham, MN
    Interesting about the display lines. Has anyone ever killed one?
    2013 Spyder RT-S SE5
    Very Active Member spyderCodes's Avatar
    Jan 2016
    PA
    Quote Originally Posted by TomB985 View Post
    I've heard of plenty of clusters being replaced but the trouble is almost always wonky analog speedo or tach not the lcd.
    The Power of Logic.
    Start Thinking.
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi SPECTACUALR SPIDERMAN,
    Re: When you say 30's you do mean celsius?
    30*C = 86*F
    Jerry Baumchen
    PS) And that is quite warm for northern France.
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Feb 2016
    France
    Quote Originally Posted by SPECTACUALR SPIDERMAN View Post
    Yes. Not "quite warm" more like stinking hot, got up to 38 degrees one day.
    You never can always sometimes tell what's least expected most!!!!
    2014 RT Std
    Cup holders
    Glovebox light
    Ignition lock light
    2014 RT , Black
    Feb 2016
    France
    That's exactly what I did, I also pegged a duster to it for extra insulation.
    SO!! there is a sensible use for the "warning card", I have removed the sticker, didn't want other bikers to see it and think I was some sort of an idiot that needed to read such rubbish before I ride, after all if you need to read the warning card you shouln't even be let loose on roller skates let alone a motorbike!!!!!!!!!!!!!!
    I think I will print a label saying screen protector to cover up the words "Warning Card".
    How to turn a piece of useless kit into a FARKLE
    2014 RT Std
    Cup holders
    Glovebox light
    Ignition lock light
    2014 RT , Black
    Feb 2016
    France
    Quote Originally Posted by Deer Slayer View Post
    Lucky you don't live in London, cost you a fortune in nicked driving gloves
    2014 RT Std
    Cup holders
    Glovebox light
    Ignition lock light
    2014 RT , Black
    Feb 2016
    France
    Be surprised if one died, LCD usually reurns to normal when the temperature drops, pretty robust things
    2014 RT Std
    Cup holders
    Glovebox light
    Ignition lock light
    2014 RT , Black
    Mar 2015
    Advance, NC
    Quote Originally Posted by agedbikeman View Post
    Just pick your nose before placing gloves there.They may not get nicked.
    Default Happens.....
    As mentioned, pulling the safety card down is a quick easy way to prevent this. I also do it when the sun is to my back on long straight roads. Now if you have a pull over cover it will be even better to keep the seat cool and people off.
    ​2012 RS sm5
    Active Member ES44AC's Avatar
    Sep 2015
    Mocksville,NC
    I have this happen at least 25 times this summer on 90+ days. I'm glad this tread was started, because I never thought of pulling the safety card down to protect it. Great tip.
    I've seen this on $3k+ 2 way radios in direct sunlight for extended periods do this as well.
    2021 RTL Marsala Dark Edition 4.13.2021
    Lamonster Riser
    Spyder Extras Docking station
    Zumo XT (my own Plug & Play cable)
    WrapMySpyder Carbon fiber partial kit.
    Baja Ron ultra performance sway bar and end links
    2015 RTS SM6 Intense Red
    born on date 3/2015 (mine on 9/12/15)
    Sold on 4.13.2021 33k of fun.
    Active Member furface90's Avatar
    May 2014
    Phoenix, Az
    Default Arizona Hot
    I have a 2013 RTS and regularly ride in over 100 in the summer and have had a few rides in over 110 and never had the display problem. But we have a dry heat, maybe it is a temp/humidity problem.
    Feb 2013
    Edinburg, TX
    agedbikerman: "If I wasn't so cleverI wouldn't need to be so good looking."
    If you'd like to alternate that line occasionally, here's another one: "I'm not conceited; conceit is a fault, and I don't have any faults."
    And if you like the spirits: "I'd rather have a bottle in front o' me than a frontal lobotomy."
    NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
    Retained the old mirrors with TricLed Signals
    General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
    Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
    Riken Raptor HR.........rear tire (at 114,200 miles)
    Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
    Gear Brake Decelerometer Module
    OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
    BajaRon Anti-sway Bar
    Kumho ECSTA AST rear tire (at 14,200 miles)
    TricLed Turn Signals in Mirrors
    2015 Limited , Intense Red Pearl
    Active Member Fjrwillie's Avatar
    Jul 2015
    Mass
    Alex
    Had the exact same issue this spring while in South Carolina and Georgia. Temps in high 90's. You description is exactly what happened to mine. I thought I was going to have problems with the bike while out for the next week and half. Temps drop display comes back to normal.
    Willie
    The Future is Not Today (Motorcycle Blog) http://nomadwillie.blogspot.com/ IBA 32847
    2015 RT-S
    2015 RT-S , White
    Nov 2012
    North Las Vegas, NV
    Yes ours went all grey. Gets hot in Las Vegas, the dealer advised us to block the sun with a towel or something similar.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
