Results 1 to 5 of 5
Thread: Plastic rivets
Hybrid View
    Active Member michrick's Avatar
    May 2015
    Liverpool, NY
    Default Plastic rivets
    How do you get them off to remove the bottom cover for an oil change?
    2016 RT Limited , White
    Bryant, Arkansas
    they are a two piece rivet, pop up the center part with a small screwdriver and then it will be easy to remove, put it back the same way
    Cruzr Joe
    Default PLASTIC RIVETS
    .......How's this for Help...If you come to SPYDERQUEST at Lake George NY in Sept. .....I'll give you a removal tool for FREE ..... .......PM me for details .......Mike
    Default Not that hard....
    If you notice there is a notch on the inner circle where you can insert a small flat screwdriver and pop the center up. Once it is up you can remove the outer section. When installing them back make sure you put the notch so it is easy to get to....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    May 2015
    Liverpool, NY
    Yeah I got it off for my oil change but I put it back on after. I know people leave it off I might the next time. Thanks for your help.
