Results 1 to 14 of 14
    May 2010
    nh
    Default Seat latch "stuck"
    Having a problem with the set latch not releasing (does not seem stuck or bound, just doesn't seem to actuate the release)
    pushing in the key it turns freely so it's not stuck
    and depressing the seat to relieve tension on the latch release hasn't has positive results.
    before I start yanking plastics off to look for the pull cord (it happened late and with work haven't had time after work to mess with it in a dark parking lot)
    a) any other suggestions to try?
    b) is the latch mechanism easily accessible from the right hand side with the Tupperware removed?
    c) any other tricks for getting at the latch?
    thanks team
    aaaaaaaaaaaaanf GO!
    Aug 2012
    CO
    My seat gets stuck from time to time. I turn the key and it doesn't want to turn, I suspect there's something binding at the top end of the cable, since I can wiggle the cable and sometimes the key then turns and unlocks the seat latch.
    Other times I reach down past the right hand flexible plastic shroud (between the instrument panel and the handlebar), and feel for the cable, and yanking on the cable will release the seat latch. I've attached a zip tied pull cord down there as my "backup" seat release for when the key gets stuck.
    JLohPhotos
    2008 GS , Millennium Yellow
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    You can't really get to the latch easily via the panels as there's a black panel covering it which can only be removed when the seat's raised - Catch 22.
    As asp125 mentioned you can get to the cable at the handlebar end. However if you remove the right hand panel that has Can-Am written on it you can also get to the cable there as well - you may even be able to thread through a bit of stiff wire with a small hook at the end to give the latch a bit more of a pull.
    You could try spraying some CRC 5.56 (I think you call it WD-40 in the US) under the right hand front side of the seat (or along by the cable mentioned above) to try a lubricate the catch a bit.
    It would also be worth trying to push back on the seat while trying to unlatch it i.e. pushing the seat towards the back of the Spyder, there is not really much play but you may be able to do it enough for the latch to free up.
    If you do get the seat up check the latch mechanism is moving freely but also the position of it and the 'pin' that's attached to the seat. You can move the position of the latch or the pin a bit (can't remember which) so it unlatches easier.
    Aug 2012
    CO
    There is a good photo link somewhere on this forum that shows how to adjust the seat/frunk pin.
    Sent from my SAMSUNG-SGH-I747 using Xparent Skyblue Tapatalk 2
    JLohPhotos
    Registered Users lizmcg's Avatar
    May 2016
    Virginia
    This happened to me awhile ago, and I did a search here to look for help. I found an old thread called "What if seat doesn't release to open and fuel" that had a bunch of information, including how to rig a bent coat hanger or other wire to get at the latch easily, which I now have in my trunk.
    ​2012 RTS SE5 purchased 4/26/2016 with 15,273 miles. (Bellatrix)
    While holding the key "down & turned", have somebody try jiggling the seat around a bit. (fore & aft, and left to right...)
    You might have enough movement in the setup, to allow the latch to release it's grip.
    (Then: look up the adjustment instructions!)
    washington state
    The last resort is take her to the dealer and have them figure it out. I'm sure they'll help you out without charge, just imagine how much $$$$$$$$ we spent to our spyders.
    2012 Spyder RT SE5 Brake pedal mod
    Active Member whitjim10's Avatar
    Jan 2013
    greenville, sc
    Took my seat lock off all you have to do is take the post off the seat problem solved.
    Default BUT THIS IS BETTER
    Quote Originally Posted by whitjim10 View Post
    ..You really should leave the post on......... just wire the latch open ..... then the seat won't jiggle around ....Mike
    Invalid Emails
    May 2016
    Columbia,tn
    Default seat latch
    I couldn't get my seat open with the key. It would not turn to release seat. It was like the cable was rusted together. Took a screw driver and had my wife pull back on the front of the seat and took a long flat screw driver and pushed the latch back to unlock the seat. Now I have a plastic tie wrap around the latch to keep it unlocked all the time. Didn't take the pin off the seat. Like it a lot better now since I don't have to turn the bike off to fuel anymore. Just put it in neutral, put the brake on and get off and get gas. No need to restart the bike and go thru the stupid card check and reset all the time.
    Aug 2008
    MA & NH
    Is it wise to fuel a running machine ?
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    Quote Originally Posted by Saluda View Post
    Diesel is OK but not gasoline. All it takes is one spark when the conditions are right.........or wrong, depending on your viewpoint. Doesn't happen all the time and you may get away with it for quite a while. Until the conditions are right.
    If you do it when I'm there, I'll say something to you. I'm not bashful! Just remember, if something goes bad, you won't be the only one hurt by it.
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    When you put diesel fuel in your Spyder: you won't shouldn't have any problems with fires...
    ...Other than getting the darn stuff to burn in the combustion chamber!!
    Seriously: NEVER try to put fuel into a vehicle that is running!
    Very Active Member Dan McNally's Avatar
    Jun 2013
    Quote Originally Posted by trucker1 View Post
    I couldn't get my seat open with the key. It would not turn to release seat. It was like the cable was rusted together. Took a screw driver and had my wife pull back on the front of the seat and took a long flat screw driver and pushed the latch back to unlock the seat. . . .
    I had the same problem on a road trip - I discovered I could lift the front right edge of the seat, just enough to be able to release the latch with the tip of a screwdriver. My dealer replaced the cable, under warranty, when I got back from that trip. I carry a small toolbox not much bigger than a paperback book, in my trunk, just for such issues.
    "Topper" is my Pearl White 2013 RT-LTD
    Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
    Happy to be a member of the Maryland Spyder Web - find us at
    http://www.meetup.com/MarylandSpyderWeb/
