2020 RT Ride Frequent Stay Safe
Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
Backrest Home Brew Mod
2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
Yup. Can't wait till they come out
Sent on Note 5 in Taptalk
BRP belt tensioner
Thanks for the pictures. How bad were the vibrations before the tensioner? Were they more prevalent at certain speeds? How much tension would you say is on the tensioner, light, medium or heavy?
Thanks again.
There is not a lot of tension on the belt. I can easily lift it up as you saw in the picture. It seems to be enough to stop the vibrations though. My wife has been up to 85mph with it and she said she doesn't feel the vibrations that she had before.
She said that she had vibrations after 40 mph and they were pretty noticeable.
Glad to hear, appears to be a good fix. Thanks again.
looks to be an awful small roller. any noise from it ? turning some rpm's !!
hope it will be a long life unit. hope there is an rt unit too.
2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
and some little stuff. setback utopia backrest, baja ron
sway bar, oem adj. air deflectors, marlin gps compass,
lamonster fbb foot pegs[modified brackets], lamonts
vibration damper, rock guard, and side case stiffener kit,
. brp comfort seat. , fomozas and
altimax, magic mirror mts, and wide mirrors.
[joyce & irvin toms]
Really hope BRP makes one for the RT.
A lot more RT's out there than F3, and they also have that issue, so would definitely make no sense on their part to only make for the F3..
Time will tell.
I think that the reason it is $50.00US is because it is plastic. Even if they do come out with one for the RT, I would not buy it. I already have enough plastic on my RT. I'm gonna stick with my SmoothSpyder that I have had for 3 years, and I have been quite happy with it. I would upgrade to the newer unit for the RT, rather than buying the one from BRP. I'm not an engineer, but I just don't see a plastic part that gets that much wear lasting as long as a SmoothSpyder or Baker Built.
Originally Posted by taxmyzer
I agree
2012 Spyder RT SE5 Brake pedal mod
BRP design Flaw
Originally Posted by Lamonster
I was talking with Len at Pitbull the other day and he said that BRP showed a belt tensioner at the dealer show for the F3 that will work on all F3's. He said it was pretty cheap to, under $50.00. That's good news for those that are bothered by the belt vibration.
BRP should make the kit available as a RECALL, you can't tell me that they didn't know of the condition!!! design engineering flaw
Not a safety issue. Recall=safety. No safety issue=no recall.
True. More appropriately it should be termed a TSB that is taken care of only if a customer reports the issue.
Regards, Rodney
2011 RT-S SE5
2016 F3T SM6
Hi
just curious where they have the unit attached? The two aftermarket units attach to what I feel could be a weak point and require cutting body Tupperware...
mark
Bullies are sad pathetic People
Pictures are in post #20
The pics do not show attachment point...
For anyone with a SmoothSpyder belt tensioner............how many miles have you ridden before having to replace the bearings for the roller?
On the road again...........and forever young!
2013 RT-S SE 5
Yesterday is a cancelled check.
Tomorrow is a promissory note.
Today is cash.......spend it wisely.
I have well over 10k on mine and its just fine.
BRP belt tensioner attaches to left side passenger foot rest.
2016 F3-L Special Series? Mods: Lamonster IPS end caps w/ Gripper 3rd pegs, GPS mount, Power Plate, Perf. Muffler; Backoff Brake Light Strobe; CD Front (amber/red) Brightsides & Tip Kit; ISCI Flag Holder w/Long Poles; BRP Signature Light, Aux Lights, Saddlebag Liners, Garmin 590 GPS; TricLED foam Grips, LEDs (Aux/headlights); Pitbull Driving Lights; RDL seat; Ultimate backrest
Previous ryde: 2012 RT-L, 26,636 miles on it when traded; 2014 RT-L, 34,147 miles on it when traded
The vibrations are tolerable for a few seconds, but beyond that they're annoying. On my F3 they can be felt a little below 4000RPM in all gears. I find myself switching gears to avoid staying at those RPMs.
I'm hoping to go for a 3-day ride in late September. I hope we can get our hands on this by then.
SpyderLovers Founder
Any idea when these will be available? Do we have a part number yet? BRP part or accessory?
Hoping to order one asap. Any info like asked above.
maybe adaptable to an rt. guys do fabricate.
