LED bulbs for 2014 ST
Hello: Wondering if someone could give me information on obtaining LED headlight and fog light bulbs for a 2014 Spyder ST. Kinda confusing trying to find the correct ones. Maybe the correct numbers, along with the best place to purchase. Thanks a bunch!
SpyderLovers Founder
This is what we have that works for the headlights.
http://www.lamonstergarage.com/h4-le...-spyder-f3-st/
I'm checking on the ST foglights now.
Originally Posted by Lamonster
I got your Headlights, They are really great! I also have the add on BRP fog lights. The fog lights are a yellow light but they still fill in nicely the light right in front of the spider. If I turn them off the LED lights do not give much light on the close in area right in front (Maybe 30 or 40'). It will be interesting to see the difference by putting in LED fog lights.
2017 F3 Limited
YESSS!!!!
I have the Lamonster LED headlights and love them. Recently picked up some BRP foglights but hoping for the LED Foglights.
LED headlights for ST
Yes!! finally there is an LED alternative for the ST! Looked at the F3 install video on lamonster's site, but what are the tips for an ST DIY install?
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
sigh >> and I have large hands. maybe I'll stick with the stock halogens.
I try to do all my farkeling myself to avoid dealer pricing and ineptness
Hi, can you please advice which size LED should I get HB3 or H4 for ST Limited Low beam?
Btw, mine has hyper flesh issues. After trying press and hold on the hazard light switch 30sec method don't work.
Any advice?
The bulbs have changed since I got mine. If you go to the XenonDepot web site you can select the vehicle and it will tell you what to use. (HID is technically illegal unless the OEM was HID or Xenon)
I have a problem with 4 way flasher. I installed CustomDynamics rear flashed and my turn signals work fine. It the 4way makes the left side barely flash. Haven't figured out how to fix yet
