Results 1 to 10 of 10
    Active Member Chrisluckey's Avatar
    Jul 2016
    Coral Springs, Florida
    Default RT rear shock install - time to install
    2016 RTS. How many hours should it take to replace stock rear shock with new Elka stage 2?I've looked on the forums and on YouTube, and can't seem to find any newer RT installs. I'm thinking about having my local Can Am dealer do the install and want to make sure they charge me a fair price. Thanks
    Default CHARGES
    If you are lucky .... you will only be charged " shop manual hours " , but since they might consider this a " CUSTOM job " the sky could be the limit........... In stead of asking US ( which is meaningless ) get them to give you a FIRM quote ...... then you can shop that around........jmho......Mike
    St. Catharines, Ontario
    Had the Elka Rear shock installed on my 2016 RT Limited during first service at my CanAm Dealer. Total cost was $400 Canadian including oil, filters, front tire balancing and Elka Shock install. Just looked at receipt and they charged me 1 hour labor or $99 to install the Elka. I think that was very reasonable.
    Quote Originally Posted by Chrisluckey View Post
    Jul 2016
    Default Took to dealer
    The Elka rear shock replacement took one hour on the RTS and the shop fee was $120.
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Default Re shock replacement
    So I take it that to replace rear shock it can be done without removing rear wheel Thanks
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    you might consider havig doc humphreys air bag rock guard at the same time.
    or does this shock not use air assist?
    [joyce & irvin toms]
    Active Member Igofshn's Avatar
    Lemoore, Ca
    My dealer quoted 2 hours. I did it in about an hour, maybe a little less.
    Default Mostly
    A one hour job times the hourly rate at your shop...as Mike stated not being an oem shock they may try for more . Only two bolts hold it in placeno matter which shock you put in...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    May 2013
    Edmonton Alberta, Canada
    Quote Originally Posted by RudyB View Post
    Yes it can be done without removing the rear tire.
    Here's a link to a short video I did replacing the shock...
    http://www.spyderlovers.com/forums/s...-Install-Video
    2014 RT-Ltd , Cognac
    May 2011
    Ocala, Florida
    Default Elka rear shock
    Is the Elk an air shock or does it eliminate the air ride system and if so what do you do with the air ride parts?
