Page 1 of 2 12 LastLast
Results 1 to 25 of 29
    Registered Users Rukpub's Avatar
    Mar 2016
    Acworth Georgia
    Default Install: Digital Voltmeter
    Hi all, This mod was inspired by Finless Bob and JT.
    JW. Metro Atlanta. 2012 RT SE-5, TircLed mirror turn signals, run/turn saddlebag lights, ring of fire, and fender tip lights, ShowChrome backrest,chrome (wide) foot pegs, SpyderPops spyclops, A-arm LED's, JT's USB Port, Digital Voltmeter ( Ebay) and Performance Powersports Scoops.
    Feb 2012
    Spring City,Utah
    Nice job, I did the same install a year ago from Finless Bob. BTW my guage over time has lost .5 volts according to a meter reading on the battery. This is a nice change and simple to do and give you better instrumentation. Looks good and nice video,thanks.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2013
    Houston
    Cool!
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Active Member Dragonfly's Avatar
    Apr 2013
    Atkins, Arkansas
    Nice, My gauge is still sitting on the toolbox, also have not figured out what to put in the other opening.
    Very nice.
    Anyone try a flux capacitor or a warp speed readout as alternative gauges?
    Apr 2013
    Atkins, Arkansas
    Thought about that but neither will work with the Proton Generator installed on the 2013 models
    May 2013
    Stanton, ca
    Very nice.
    http://www.oreillyauto.com/site/c/detail/EB00/121G.oap
    Oh and get the other part too!
    http://www.oreillyauto.com/site/c/de...B00/121GMF.oap
    Bob
    2011 RT-S SM5 - Black
    Pragmatic Member Pampurrs's Avatar
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by Dragonfly View Post
    I just left the disabled fuel gauge in the left opening after I installed my Voltmeter in the right one. I topped off the tank before unplugging it so it's stuck on full. I'm just leaving it there until I decide what to put in its place.
    Pam
    • 2015 RT-S Special Series / Red & Black
    • Baja Ron Sway Bar
    • Utopia Backrest
    • F4 Customs tall and wide vented windshield
    • Stebel Super Loud Air Horn
    • Baker Built Air Wings
    • LaMonster Highway Pegs
    • SpyderPops Exhaust Block Off Plate
    • SpyderPops KOTT Grill
    • SpyderPops Belt Guard
    • Cat Bypass
    • Laser Alignment by Squared Away
    • TricLED Fender Lights
    • General Altimax RT43 rear tire
    • Dual flag holder
    • Mud Flap
    • A$$hole seeking missile system
    Feb 2012
    Spring City,Utah
    Go ahead and install your volt meter. Just leave the gas gauge there inactive. As soon as I pulled the power my needle dropped all the way down unlike Pam's. It took me a year to finally put something there. For now I am using it as a place to mount the GPS I bought to replace the one I lost. I have seen some that mounted USB plugs there or power sockets. I thought of an altimeter but couldn't find one I liked.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Apr 2013
    Atkins, Arkansas
    Default A Clock
    Along with the volt meter I bought the Water Temp Gauge ( no I don't now why, thought about getting underbody readings from it.) However today I found the perfect gauge, a Digital clock, ordered it and should be here in Friday.
    http://www.ebay.com/itm/201008639085
    This item has perimeter lights that countdown the seconds.
    By the way, my fuel gauge also maintained the volume setting after disconnecting.
    Mar 2015
    San Tan Valley, AZ
    Nice clock! Let us know how the install goes. I may want that myself.
    Pam
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    Apr 2013
    Atkins, Arkansas
    Default All Installed
    Clock came this morning, 3 day delivery, not bad.
    Clock has 4 wires
    Black - Ground
    Red - Switched Positive
    Yellow - Continuous Positive
    Orange - Dimmer
    Clock will not work unless yellow is connected and to set clock, set button is on the back. Instructions say it is 12/24 hours however have not found the 24 hour setting (yet)
    I connected the ground to existing ground from old Gauge and connected the red and orange to existing connection for old gauge light. Since I needed continuous power for the clock I ran a yellow from the Battery and connected the Volt Meter to the same wire as the clock.
    Sort video of the clock cycle.
    Aug 2016
    Florida
    Default voltmeter and power sourse hook up
    Quote Originally Posted by Rukpub View Post
    Was thinking of installing digital voltmeter and cigarette lighter power adaptor on the dash. Since you tapped into the existing harness used for the fuel and temp gauge did you had any issues with the computer because it is recognizing different components or any other electrical problems?Thanks..
    Invalid Emails
    Jul 2014
    Rotonda West,FL
    On my 16 RTS there are deutsch connectors on the guage. can i after looking a a wire diagram assume and i hate that word
    that or w/rd = +
    and bk w/vt = -
    and the 3rd color in each connector is the fuel and temp sensor?
    Aug 2016
    Florida
    Default Wiring
    Quote Originally Posted by CapeSpyder View Post
    that or w/rd = +
    and bk w/vt = -
    Thanks, still not sure which wires to connect. I checked with a multi-meter and found that the triple connector wires are Ground for Black, 12v+ for the Orange and 6v+ for the Blue. The additional Orange that has a bayonet connector is also 12v. All are powered by the ignition switch. My concern isn't as much about just connecting power and ground but concerned about any issues that may cause the computer to read a fault and or cause a failure. Has anyone had any issues after hooking up an accessory in this manner?
    Invalid Emails
    Jul 2014
    Rotonda West,FL
    Im thinking the blue is the sender wire for the temp and fuel
    CapeSpyder
    Sent From my Note 5
    Invalid Emails
    Mar 2013
    new jersey
    How does it the voltmeter plug in is it a simple plug in with existing wires that we disconnect for the existing gauged
    Invalid Emails
    May 2015
    longview, tx
    Default Usb Power where Fuel Guage is
    I would like to know how I can get usb power in place of the fuel gauge. I have seen it in several photos but cant find where to purchase it.
    Mar 2013
    Marion, Arkansas
    Look at the home page and several venders have these for sale. Try Jt's as I know he does for sure.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Active Member wanderingman's Avatar
    Dec 2014
    Ave Maria, Florida
    Default My ignorance
    I have seen several posts regarding disconnecting the fuel gage. One implied a second digital fuel gage that shows up when the analog gage is disconnected. Is this correct. If so please tell me more, as replacing the fuel gage with a weather proof USB would be great.
    Dec 2014
    Central, Florida
    Here is another option:
    https://youtu.be/pbxnh3VeLL4
    Sent from my SM-G935P using Tapatalk
    Invalid Emails
    Jul 2014
    Rotonda West,FL
    Quote Originally Posted by wanderingman View Post
    Yes, when you disconnect both gauges, yup both. On the digital display on the left side the gas will show and on the left the temp.
    If you are not replacing the temp with something just leave it.
    I'm putting in the double usb in that middle switch spot and a clock on the left and volt on the right
    Dec 2014
    Central, Florida
    And here's even another reasonable alternative:
    https://www.amazon.com/gp/aw/d/B017U...er+accessories
    Dec 2014
    Ave Maria, Florida
    Thanks a lot for the reply. That is very helpful. I was thinking of the USB in the middle switch position also, but when I popped the cover saw it was an odd shaped hole. Of course a dremel can fix that, but I was thinking that since I want to be able to connect it to my phone mounted right above it, the USB wire might rub constantly on the glove box door and damage the paint. In the gage position I could run the wire through the phone mount and keep it off of the paint.
    Idaho
    Quote Originally Posted by arecibo50 View Post
    The mount looks like a cheap Chinese knock-off of the Rammount system. The total price is less than you need to pay for a good reliable USB charger. I would be leery of it.
    2014 Copper RTS
