Middle Dash switch
Does anyone have any pictures or instruction on how to put a switch in the blank middle spot between the shock and handgrip switches on an RT?
I may have pictures at home, but it isn't terribly difficult. The only trick is that there is a round hole under the rectangle cover. If you take off one of the main side body panels and pop the switch blank out you can fish wires without having to disassemble much else. You just need to pick a switch and cut the hole to just the right size. I added some thin double stick tape/foam around it too to help act as a gasket.
2017 Can Am Commander Limited
2012 Cadillac CTS-V Black Diamond
2020 F3 Limited Magma Red (miss the 2011 Viper red)
2010 RT622 - Black
Thanks thats kinda what i thought it would be. Just didnt know about pulling a panel.
CapeSpyder
Sent From my Note 5
Pragmatic Member
Check out this thread, it may be helpful.
http://www.spyderlovers.com/forums/s...Switch-Cluster
I'm installing that USB port soon. It requires removing a side panel so I can wire it to the battery.
Pam
- 2015 RT-S Special Series / Red & Black
- Baja Ron Sway Bar
- Utopia Backrest
- F4 Customs tall and wide vented windshield
- Stebel Super Loud Air Horn
- Baker Built Air Wings
- LaMonster Highway Pegs
- SpyderPops Exhaust Block Off Plate
- SpyderPops KOTT Grill
- SpyderPops Belt Guard
- Cat Bypass
- Laser Alignment by Squared Away
- TricLED Fender Lights
- General Altimax RT43 rear tire
- Dual flag holder
- Mud Flap
- A$$hole seeking missile system
This is a middle "switch" that fits into the empty space between the rest of the switches of thr RT. It's called a carchet car and is available from J.T's. Spyder Store. I currently have one mounted on my 2012 Can Am Spyder RT-SE5. It looks like OEM, and provides two USB jacks.
I just bought one fro J.T. and installed directly to the battery. I didn't really care that it was always hot though. Then I stumbled across a video by Pierre from Spyder TV.
2016 RT-S Special Series
