Results 1 to 7 of 7
Hybrid View
    Jun 2013
    New Jersey
    Default Wireless Controller for heated gear
    I am investigating which type of heated gear controller to purchase, wireless or permanent. The most appealing is the wireless system, however I am hesitant to purchase it after reading about the DESS problem which may be related to interference from other wireless devices. To date, my 2014 Spyder RT has not suffered from this problem. I am looking forward to reading all comments so I can make a more informed decision.
    Thanks.
    Jerseyspyder
    Coolidge Arizona
    I installed a permanent dual controller on my 2014 RTL
    I figured I would have to wires going from the bike to my jacket anyway so why have wireless
    Default Agree...
    considering the function of the heated gear I would rather not depens on wireless. Ours is hard wired and we have no problem with it. Even when I forget walking off just unplugs it and you just hook it back up when you take off. Guess it's all in where you put the controller...I have a dual, gloves and liner and the wife has a single. RS has no hand protection and heated grips do nothing for you.....
    Jun 2011
    Lynden, WA
    I use the wireless controller and have since I bought my 2011 and now my 2014 RT. No Problems related the DESS but, I made sure the powder that goes to the clothing is isolated via a relay and a diode.
    Feb 2012
    Spring City,Utah
    I have the wireless controls. I like them they work very well and I will never buy another set. It adds useless expense to the purchase and needless complication. You are still wired in, they can't send the power wireless so for me there is no point.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jul 2011
    Mitchell, Ontario, Canada
    Don't be very concerned about wireless devices interfering with the DESS. The DESS only operates for a couple seconds after the key is turned on. After that it does nothing until the next time you turn the key on. So unless you plan on putting the wireless controller beside the ignition switch and press the button on it at the same time you turn on the ignition switch. Nothing bad will happen.
    2018 F3 LIMITED
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    Thank You BB; the sounds of reason and logic coupled with intelligence!!!!!
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
