The two covers next to the key have wires and a plug connected to them, I'm nosy and pried
them up looking for a place to put an aux power switch.
what are they used for? See attachment.
they probably have something to do with the control switches on the handle bars. It may there for wiring incase the shop has to replace any harness wires. But that's just what I think they are for. Maybe someone smarter than me knows. LOL
The switch to the left of the key (as you sit on the Spyder) is for heated grips. On the right of the key is for fog lights.
2020 F3 Ltd
Spyderpops Bumpskid Spyderpops Brake/Run/Turn Signal LED's
Lamonster Garage LED Fog Lights and Headlights 2013 ST-S retired 1/9/16 at 25,061 miles
The fog light kit from Lamonster is really great and does indeed connect right to that wiring harness at that location. Even uses the stock connectors. Truly plug and play. Happy with mine.
If I get a fog light kit will it connect there and be where I put the switch?
If you look under the cover you'll see the wires that are plugged in to the right blank. Those are the wires for the fog lights (at least they are on the F3 Limited). Lamonts LED fog light set comes with a switch that appears OEM and fits in that right hole.
