Results 1 to 18 of 18
    Active Member Stumpy6Guns's Avatar
    May 2016
    Valley Center, CA
    Default Ryding in the rain
    It hasn't rained here in months, and I've never ridden in the rain. How do you deal with the rain on your helmet visor or goggles? Rain-X? Wipe every 10 seconds?
    Myron Wooley
    USMC 1975 - 1979
    2nd Spyder: Pearl White 2016 Spyder RT Limited, purchased December 18, 2016 with 1 mile
    First Spyder: Pearl White 2012 Spyder RT Limited, gone to a good home
    Very Active Member Bam Bam and Pebbles's Avatar
    Nov 2014
    Rural Hall NC
    I go faster so the wind blows it off. Of course I use a shorty windshield so I get plenty of wind on my helmet.
    Current Ride
    2015 RT-S SM6 Cocaine
    Pearl White
    Diamond R Web Armrests
    Shorty Windshield
    Previous Ride
    2012 RT SM5 The Beast
    Pure Magnesium Metallic
    Default Here's how I do it....
    As you ryde along, turn your helmet slightly to the left and then right or visa versa and the rain will sheer off....
    ​2012 RS sm5
    x 2
    Sep 2015
    Chilliwack, BC. Canada
    I just ride faster, so the rain can't catch me.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Dec 2013
    Never ridden in the rain?? You've missed one of the great joys of Spyder Ryding!!
    Just take it easy, slow down a little from the speed you'd usually travel at (more for heavier rain!) & give yourself more 'safety gap' behind the car in front so you've got a little more reaction time/space if they stop in a hurry, & like others have said, gently move your head from side to side a little as you ryde along so the change in attitude blows the drops off your visor (& gives you more chance to check out the behaviour of the surrounding traffic!)
    While ATGATT is always a good idea, adding water resistant or proof gear to help keep you warm & dry inside when it's raining is smart; & full-finger & armour backed or padded gloves on your hands plus a full-face helmet with a Pin-Lock anti-fog insert is a really good idea if rain is likely - at Hwy speeds rain drops hitting bare skin or your face can hurt, and hail hitting your un-protected fingers or face can really do some damage!!
    And just as an aside, if you are heading out to go riding in the rain, especially if it's after a long dry spell so the roads haven't been washed clean of oil & tire residue in a while, dropping your tire pressure by say 5-10% (a couple of psi or so?!) can be a really smart thing to do!! Lowering your tire pressures a bit for the cold & wet road surface means the tire casing will get to flex a bit more & thereby heat up to operating ramps a little quicker than otherwise, as well as making the tread compound a tad warmer overall & therefore 'stickier', improving traction in the wet. And it also means the tread contact patch on the road surface can flex & conform to the slight irregularities in the surface a bit more & better; giving the grooves, sipes, & tread blocks of your tire tread pattern a better chance of pumping water out of the way & thereby avoiding hydro-planing while gripping the road better too!!
    Active Member Kwalsh's Avatar
    Oct 2014
    cohoes ny
    what he said!!! but most of all enjoy it because it will happen and there is nothing you can do about it
    If you normally ride looking through your windshield: drop it down, and try looking over it. It's easier to look through just the visor under these circumstances.
    ...And turning your head to the side, to blow the rain off of your visor works pretty darn well...
    Active Member deer30084's Avatar
    Jun 2016
    Tallahassee, FL
    It's fun to ride in the rain with your helmet and rain suit on and pass the motorcycle riders in their t-shirts.
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
    Active Member JayD's Avatar
    Oct 2015
    Cumming, Ga
    Rain X
    2014 Spyder RTS
    Tri Axis Handlebars
    Big Bike Trailer Harness
    Rivco Front Bumper (Black)
    Rivco Highway Pegs
    Ultimate Seat
    Garmin GPS
    Trailer Hitch
    Aluma XL Trailer
    Stainless Grill Covers
    Cupholder
    Spring Stiffeners
    Rivco Floorboards
    Greenville Tx
    If you use rain X make sure it is the kind for plastic windshields. Regular rainX can ruin your plastic. I have found that riding in the rain on a spyder is not much different handling wise than riding in your car.
    2017 F3 Limited
    Active Member kitkat61's Avatar
    Sep 2015
    Chesapeake, VA
    Default Yes - make sure it's Rain-X for PLASTIC
    Quote Originally Posted by AY4B View Post
    Regular Rain-X will ruin your helmet and bike in a hurry, but they make one specifically for the plastic windshields of motorcycles and boats (works on visors too). I haven't found a local source, but you can buy it off of Amazon.
    GWRRA Virginia District Director. Because we don't care what you ride, just that you ride safe!
    Tri Axis Handlebars / CB & upgraded antenna / GPS & Cell phone integration / Trailer Hitch / FOBO TP Monitors / Black & Pearl Ultimate seat
    Spyder Cuff / Custom Paint / Laser Alignment / Flag Poles / 3rd & 4th Rear Brake & Turn LED's / Gear Brake Decelerometer Module
    A whole bunch of lights from LaMonster and SpyderPops
    Oct 2007
    Quote Originally Posted by kitkat61 View Post
    Cycle Gear stores carry a product called Rain Coat Pro that seems to work well.
    Jul 2014
    Mint Hill, NC
    I purchased my Rain X for plastic windshields from Auto Zone or Advance Autoparts, can't remember which. Works satisfactorily.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    i use a spray wax called protectall that works great on w/shields.
    unless i stop i never have to run the wipers. but then i havent been in a rain on
    bike or trike for years. we just do day rides.
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    Active Member WEB-WVR's Avatar
    Sep 2009
    Albany, Oregon
    With the windshield I have not had any real rain issues. Rain tends to blow off the face shield....crack it open enough so it does not fog from your breath.
    I hope some are joking about speeding up. If anything, get in the slow lane and slow down. Riding in rain can be dangerous, visibility of other vehicles, traction, road wash hitting you, etc. If the rain is super heavy or a lot of water standing on the road....may be a good time to stop for a long lunch !
    The Spyder is a great machine but it is not water skis or a boat !
    Craig From Albany Oregon
    Invalid Emails
    Jul 2014
    Henderson NV
    I found Rain X for plastic at Walmart.
    Jun 2013
    queens ny
    to be honest, i try not to ride in the rain. i have been caught in a few downpours and just kept wiping the shield with my glove. if the rain is really bad, i try to find a overpass or pull of the road to find some shelter
    NO BIKE AT THIS TIME
