ANTENNA
Does anyone know the part number and cost for the BRP short antenna?
I believe these came out with the 2016 models. I just shapped mine off and do not want to replace it with the long one that it came with.
Update,
I found it on Cheapcycleparts.
Antenna - 710005084 for $57.99
Reason: Found anwser
2021 Sea To Sky, 2020 RTL
but our benefits don't?
Wow that ain't cheap. You can get a shortly a lot cheaper than that at Walmart.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I will be checking that out for sure. Good thing I don't listen to the radio so I have time to find a cheap fix. To bad BRP doesn't sale the little cover for the hole as I would than just plug it.
try lowes for a rubber plug
New antenna with better range and much more solid, Just got this from Spyderpops and it comes with a new style boot that won't fly off and works with half or full cover without breaking, what do you think, looks good don't it?
about $25.00 shipped to you
Cruzr Joe
How opportune....
Spyderpops has one to fit the bill....check with him as mentioned above....
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Cruzr Joe
Thanks Joe,
I just ordered one.
Les
Update,
HI, I got my short antenna(part # 710005084)and 2 antenna bases from Pitbull.
Short antenna..............................$57.99 and 2 antenna bases ( $15.99 each). I have a 2014 RTS-SE6, see pictures:New Radio Antenna on 2014RTS-SE6 001.jpg New Radio Antenna on 2014RTS-SE6 002.jpg New Radio Antenna on 2014RTS-SE6 003.jpg
Look at "My Album". I replaced my original last month. It took me about 5 minutes to change out the original.......long antenna. I did not use lock tite. The radio stations are clear. Deanna
Reason: added to post 8/31/2016
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
Rubber shorty can be purchased at Walmart for under $20. Comes universal with plenty adapters. Works just fine.
They are not bad ................... these just are a little shorter and get very good reception. And look good.
Cruzr Joe
Or?......
Hi Joe,
I've been fighting with my OEM reception since the day I brought the bike home... It's down to either a bad antenna, or a bad receiver...
Have you checked your hearing? No offense, but as we get more mature, sometimes.......
(That's why I type bigger, so everybody can hear!)
~Sandee~
~Sandee~
2016 RT-L (Purchased used in February 2018)
RT Dash Mount (from JT's Spyder Store)
Kuryakin Trident Highway Pegs
Hopnel Pouch
Magic Mirrors
Spyderpops Foam Handgrips
Iron Butt #35273
Girls on Spyders #2779
I bought a small rubber antenna from walmart at cost of 10.00 CDN. I find that it woks better than long stock antenna.
Just a question, how long is the "long stock antenna"
I know the one I have is a pain when getting the covers on and off the bike
2017 RT-S
Bump Skid - Spyderpops
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
3 PC Mesh Zippered Lid Net Set - TricLED
A arm LED's - Safety LED's - TricLED
Mirror Sequential turn signals
Glo-riders
LED rear turn signals and reverse lights
Front Grills
Third Brake light
Larson Scanner
Light Up - Sue Hopper
You have a short (compared to older models) antenna, the original is about twice as long
Cruzr Joe
You have a short (compared to older models) antenna, the original is better about twice as long
Cruzr Joe
2017 RT-S
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
Glo-riders
Front Grills
Third Brake light
Larson Scanner
Delete the word better, is about twice as long
... what?
My ears are fireproof, bombproof, and ready for War!
As I was listening to some "light music" from Yngwie Malmsteen today (look him up...), I heard every note that his guitar played...
Seriously: I DO have a reception problem, and am wondering if it's worth spending $25, to see if a new antenna might solve it.
If and when you get a new (shorty) antenna DON'T use any locktite on it. Had to cut off my wife's antenna to get a socket onto it to get it out. Was locked in there tight!.
(her bike has always had a reception problem) Cleaned out a crap load of blue locktite from the threads. Screwed in a Walmart shorty in without any locktite and took it for a ride, it had to have doubled the reception distance for her.
Now ordering one of the Spyderpops antennas to see if it increases distance even more.
When my bike was in for servicing last Month: I had the technician remove the antenna, and remove all of the Loc-Tite...
I had hoped that this would make a difference... It did: but it was a minor difference...
In the past: the entire unit has been pulled, and all of the connections checked, and re-checked.
We're now down to just two possibilities:
A bad antenna
A bad receiver
A bad antenna
A bad receiver
Bad Ground?
Thanks, but we checked that one; two years ago...
