Results 1 to 10 of 10
    Jul 2016
    Coral Springs, Florida
    Default RT rear speaker sound
    2016 RTS. Is there a way to get the rear speakers to work with iPod in trunk?
    Nov 2012
    North Las Vegas, NV
    There should be a setting to turn them on under "mode" on the dash. Check the fader settings in audio.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    May 2013
    Stanton, ca
    First you must set the system to Aux. function to use an I-pod or MP-3 etc..... Then go to Audio settings and make your adjustments to suit ........Mike
    Not correct.
    You set it to AUX for a MP3 player. That is any player that you connect via the 3.5mm audio plug.
    If you have a supported iPod you use the iPod cable. Set it to iPod which will show up ONLY if you have a supported iPod connected.
    Bob
    Default I-POD
    Quote Originally Posted by finless View Post
    Not correct.
    Bob
    Thanks for the correct info ..... I have deleted my Post ..... I only have an MP-3 and thought they worked the same ....mea culpa, mea culpa ........Mike
    Jul 2016
    Default No sound in rear
    Not correct.
    Bob
    That is the way I have it. I'm using the iPod cable. Get songs on dash. Can skip songs, etc. just don't get sound out of rear speakers. Balance set to middle. Just wonde5ing if there is way to get iPod sound out of rears.
    The input from the rear port is just that: input. There's nothing about it, that prevents it from being distributed through the system in the manner specified.
    Are you "473% surely positive", that you're getting sound from the rear speakers, when the radio is playing?
    (Sorry: it had to be asked.)
    Kennesaw, GA (Atlanta Area)
    I wonder if one of his speaker wires is not connected and thus causing no sound. Easy enough to pop off the rear speaker and check those connections if the "Fade" is not working.
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by Chrisluckey View Post
    Balance is middle but what about fader?
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Jul 2016
    Default Resolved
    OK issue resolved. By having the FADER set to CENTER, the fronts were over powering the rears. Had to move balance more towards the rear to hear both equally. Thanks to all for the input.
    Thanks for letting us all know that you found the answer!
