Results 1 to 10 of 10
    Active Member Fjrwillie's Avatar
    Jul 2015
    Mass
    Default Not a Big Problem - Just looking to see if it has happened to others
    Both of the screws on the bottom of the console front plate worked themselves out and went by by. Replaced one and then a couple of weeks later the other one worked its way out.
    Of course finding a replacement in a hardware store is never a perfect match. I believe the original are M5 X14 and all the stores I was in only had M5X16 so purchased 2 washers to take up a bit of the length for each.
    I simply can't figure out how these work themselves out.
    So has this happened to others ???
    Own a 2015 RT-S
    Willie
    The Future is Not Today (Motorcycle Blog) http://nomadwillie.blogspot.com/ IBA 32847
    2015 RT-S
    2015 RT-S , White
    Jul 2011
    Mitchell, Ontario, Canada
    Use thread locker nest time. A small dab of blue loctite will work.
    Screws used to fasten plastic panels cannot be very tight or it will damage the panel. So you have to use some sort of thread locker. The OE screws had some.
    2018 F3 LIMITED
    Jul 2015
    Mass
    The ones that went bye bye were the OE ones, so if BRP used locktite it must of been less than a pin head.
    Willie
    2015 RT-S
    2015 RT-S , White
    Mar 2016
    Astoria, Oregon
    I had one fall out also. Took the parts kid at the dealer 45 minutes to find one. Replaced under warranty.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    Greenville Tx
    You can just go to cheapcycleparts.com and get replacement screws. I ordered some yesterday for my body panels along with a few other things. Gas cap and the bracket that holds the right mirror. I can not get the mirror to not bounce around and found that the bracket needs to be replaced. Apparently the last time I removed it, my kung fu move required to remove it must have been too good.
    2017 F3 Limited
    Registered Users Uruzgan's Avatar
    Jul 2016
    SE MA
    Funny you should mention that... I also have a 2015 RT, and after returning from the dealer for a few things, I noticed the left screw on the front console was missing. I thought maybe they did something up there and forgot to put it back. Now Im pretty sure it went bye-bye
    Yup, Time to break out the locktite.
    Mar 2013
    Marion, Arkansas
    I also had one come out, but luckly it came out when I stopped and I saw it fall to the ground. Actually it happened during Spyderfest 2016 after stopping in parking lot at vender village. I guess I was lucky.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Invalid Emails
    Oct 2015
    Dade City Fl/Minetto, NY
    Default Loose bolt
    I also had one back out on my 2015 RT. I went to Tractor Supply and bought 4 hex head replacements. I have purchased OEM Torx bolts from my local Can Am dealer but have not yet swapped them out.
    Active Member GeorgiaBill's Avatar
    Aug 2015
    Marietta, GA
    Default Console Bolt Missing
    I'm also missing one console bolt. My local dealer is struggling to find the part number. Would you look on your receipt and tell me the part number?
    Thanks
    -Bill
    Quote Originally Posted by Bdomini View Post
    2019 Black F3-T
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    dash cluster screw was gone one day . other 3 were loose. got a bunch of different
    ones ordered for replacement. also extra mirror pieces. might need spares. --irv
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
