Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: TWISTIES
    Active Member Justacruisin's Avatar
    Jan 2015
    Ft. Worth, Texas
    Default TWISTIES
    Rode up to Arkansas last weekend with 4 Harley riders. They would take the curves 10 - 20 miles over the speed limit. I would take them 10 miles hour slower.
    what i'm I doing wrong. I thought I would run off the rode.
    HELP
    JUSTACRUISIN (Slowly)
    Active Member Fjrwillie's Avatar
    Jul 2015
    Mass
    Quote Originally Posted by Justacruisin View Post
    HELP
    How long you been riding the Spyder ??
    Were you comfortable with the speed you were doing. Worst thing is ride trying to keep up, putting you out of your comfort zone. They will wait for you to catch up.
    What specifically kept you from riding at the higher speed.
    Willie
    The Future is Not Today (Motorcycle Blog) http://nomadwillie.blogspot.com/ IBA 32847
    2015 RT-S
    2015 RT-S , White
    May 2013
    Apex, N.C.
    HELP
    It is something that will just have to come with experience. I have had my spyder for 20 months now, and have yet to come across a harley that can keep up with me in the twisties. I know there are some out there, I just haven't come across any yet.
    Nov 2012
    North Las Vegas, NV
    It will come with time. You must lean your body into the turns and you will be the one waiting for them. A Bajaron swaybar and a laser alignment sure helps too.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Aug 2013
    Northern California
    Default Thin this way
    Push Push Pull. Push with yiyr outside hand, push with your outside foot, and pull with the inside hand, all while leaning into the turn!
    Default Relax...
    A ryde is not a race and you are doing fine .stay in your comfort zone and be safe. Those that do get there did not do it overnight. It takes time and practice. I can double the posted speed but have come to find it is more fun to take them in stride. You will get better....
    ​2012 RS sm5
    Jan 2015
    Ft. Worth, Texas
    Default twisties
    Quote Originally Posted by Fjrwillie View Post
    Willie
    No problem with straight and long curves. 70-80 mph no problem. Tighter curves fills like the going to drift off the road. Or through me off the bike like ridding a JET-SKI.
    I may be pushing and pulling too hard on the handle bars. or not putting pressure on the right foot.
    ridding the Can-Am, 1 1/2 years. rode Harleys for 35 years.
    Sep 2012
    Junction City, KS, USA
    First - ride your own ride. You're not in competition.
    If you want to go faster, shift your body weight to the outside of the curve.
    Don't forget to steer!
    PrairieSpyder (Patti)
    Quote Originally Posted by PrairieSpyder View Post
    If you're racing: you need to be off the street...
    Greenville Tx
    If you want to go faster, shift your body weight to the inside of the curve.
    Fixed
    2017 F3 Limited
    Sep 2012
    Quote Originally Posted by AY4B View Post
    Fixed
    Tnanks!
    Aug 2013
    Northern California
    Tnanks!
    Thank goodness! I was looking to see them flying right off the motorcycle!
    Actually; it depends on how you want to explain the process...
    You plant your "outside leg", and put your weight on that peg (or floorboard...).
    And then lean to the inside of the turn!
    Greenville Tx
    Always look where you want to go on a twisty. It helps to shift your outside foot as far to the outside as you can, sometimes I will have my heal hanging on the outside of the footboard. Even better is to get some highway pegs. Lamonster sells some pretty nice ones. You can use the pegs to almost stand up on that outside leg while you lean in. It gives you a wider stance which I find quite helpful on the twisties. Also keep your revs up. the main thing is to stay in your comfort zone. There is always someone that can pass you up. I am leading a ride on Saturday for East Texas Spyder Ryders from Rockwall to Commerce. We will be taking some twisties, You are welcome to come and get some practice. http://www.spyderlovers.com/forums/s...Eggs-July-30th
    Doesnt Lamonster sell a Tshirt that says If you pass me, I wasnt racing?
    2017 F3 Limited
    Danbury Connecticut
    I know this is a repeat of what others have said, but the first and most important safety tip is to ride your own ride. If you're comfortable with your speed, then don't push it.
    Second, others have described the technique for cornering on a Spyder which is different than riding a two wheeler.
    Third, if you insist, there are technical modifications you can make which can increase your ability to turn corners.
    The Baja Ron swaybar and/or Elka shock absorbers minimize the amount of body roll and help increase cornering speed.
    Before spending any money to modify your spyder, just as yourself "Why ?" Is it so bad riding the way you do ?
    As always, my free advice comes with a double your money back guarantee.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Do you have a BajaRon sway bar and aluminum links? Laser alignment?
    I typically can do twisties 10-20 over limit and out maneuver my HOG friends.
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Jan 2015
    Ft. Worth, Texas
    Default twisties
    I have the Baja Ron Sway bar, had the laser alignment three weeks ago. I think ill add foot pegs and new Elka shocks.
    Thanks to All.
    Justacruisin
    Invalid Emails
    Sep 2015
    Cheshire Ma
    So edmarble your saying more body roll and less weight on the inside tire makes for better cornering ????
    Jun 2010
    Las Vegas
    Maybe its just me but it doesn't sound like a good idea to tell someone who isn't comfortable on curves to put their feet on highway pegs.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Sep 2012
    Quote Originally Posted by SpyderAnn01 View Post
    , too!
    Linden, CA
    Sounds like your still learning how to control a Spyder,
    they will corner fast but you best get used to holding on
    and leaning into the turn, DON'T counter steer...
    keep practicing.
    Dave
    HELP
    Aug 2007
    Greeneville, TN
    There are so many aspects involved in getting through twisties quickly that it's difficult to adequately assess why someone isn't doing as well as they think they should. The machine, in this case the Spyder, is just one aspect.
    As with everything in life, you cannot excel beyond the weakest link. If that is the machine you're riding then that is where the improvements need to go. But the rider is also a huge factor.
    The things I commonly see are;
    1- Braking late and Hugging the inside line going into the turn. It's the natural thing to do and will get you into a lot of trouble every time. You must always start from the outside line, apex to the inside line and then accelerate going out of the turn as you fade back to the outside line as you exit the curve.
    2- Looking right in front of your Spyder and looking where you DON'T want to go. Instead, you need to look well ahead of where you are and focus on where you WANT to go.
    3- Trying to keep up with a better rider. Not riding within your comfort zone. Basically, getting in over your head.
    All of these issues come very naturally. What comes naturally is usually the exact WRONG thing to do. Without understanding the dynamics of a curve and how it needs to be systematically approached. Going faster may well be a very bad idea.
    Don't get me wrong. I am no expert. I've just spent a bit of time studying the techniques needed to do it right. And they make all the difference in the world.
    Invalid Emails
    May 2011
    Tulsa Oklahoma
    Just came back from my 3800 mile ride 3 days ago, my wife rode the Spyder, my daughter the Ninja500 and i rode the Rocket, i had trouble keeping up with both of them, my wife was taking the curves at Bear Tooth Pass like a demon, like the others say, practice makes perfect!
    Active Member Koop's Avatar
    Feb 2016
    Where ever we can ride
    One of the attributes a Spyder shares with a motorcycle is the fact that the rider can affect the center of mass. Dropping your shoulder to the inside of the curve and lowering your upper body will lower the center of mass and reduce roll. This keeps all three wheels planted.
    When I road raced motorcycles, I often had my upper body next to the fuel tank on the inside of the curve and my head at the level of the clip-ons. With a knee slider on the pavement this was a very stable and fast way to take a turn.
    2009 Spyder Roadster
    Full-time in a 2003 Alpine Coach
    40' motorhome - we live where we're parked
