Results 1 to 16 of 16
    Active Member drhunt204's Avatar
    May 2016
    S.E. Missouri
    Default I got a small surprise when I took my front wheels off my RS.
    I took my front wheels off my RS yesterday for the first time (putting on new tires). I loosen the lug nuts on one side and then jacked up that side and removed the tire. The surprise was when I went to the other wheel and tried to loosen the lug nuts I was able to spin the tire on the smooth concrete floor!
    I ended up putting the first tire back on and lowering it back down so I could loosen the lug nuts on the opposite side. After that it was no problem to jack up each side and remove each tire. It may have just been a special set of circumstances but if you are removing both front tires on an RS you may want to loosen the lug nuts on each side before jacking up and putting the stand on your first side. It could save you some time.
    Jun 2010
    Las Vegas
    That's how the muscle man in my house does it, loosen lugs on both sides then jack Spyder up.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jun 2014
    ny
    On my spyder i crack them first then jack it up
    Pragmatic Member Pampurrs's Avatar
    Mar 2015
    San Tan Valley, AZ
    That's how I've always removed my front wheels, loosen lug nuts on both sides before lifting.
    Pam
    • 2015 RT-S Special Series / Red & Black
    • Baja Ron Sway Bar
    • Utopia Backrest
    • F4 Customs tall and wide vented windshield
    • Stebel Super Loud Air Horn
    • Baker Built Air Wings
    • LaMonster Highway Pegs
    • SpyderPops Exhaust Block Off Plate
    • SpyderPops KOTT Grill
    • SpyderPops Belt Guard
    • Cat Bypass
    • Laser Alignment by Squared Away
    • TricLED Fender Lights
    • General Altimax RT43 rear tire
    • Dual flag holder
    • Mud Flap
    • A$$hole seeking missile system
    Default All of the above...
    But then I use an impact air gun and it dosen't matter... I just have too many tools..too many years in the industry...
    ​2012 RS sm5
    Jun 2014
    ny
    since i also hand torque my lugs on for my , i am not too worried about them being stuck on or frozen
    Very Active Member pitzerwm's Avatar
    Nov 2014
    TriCities, WA
    I'd recommend this method on any vehicle tire removal. (Loosen before jacking up.)
    One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    Default Loosen lug nuts
    ​Or you can also have a helper step on the brakes
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Active Member deer30084's Avatar
    Jun 2016
    Tallahassee, FL
    Was it a motorcycle?
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
    Very Active Member Ron2andia's Avatar
    Jun 2012
    Phila
    Good advice!
    Live, Love, and Ride! God Bless!
    Very Active Member Bam Bam and Pebbles's Avatar
    Nov 2014
    Rural Hall NC
    I thought that loosening the lug nuts and then jacking it up was the only way to take a wheel off.
    Current Ride
    2015 RT-S SM6 Cocaine
    Pearl White
    Diamond R Web Armrests
    Shorty Windshield
    Previous Ride
    2012 RT SM5 The Beast
    Pure Magnesium Metallic
    Linden, CA
    Default I jack mine up and then.....
    I grab my half inch impact wrench plug it into the airline and zip them right off then I reinstall them by hand and use a torque wrench to tighten up
    eQUOTE=Bam Bam and Pebbles;1161740]I thought that loosening the lug nuts and then jacking it up was the only way to take a wheel off.[/QUOTE]
    Nov 2014
    Rural Hall NC
    [/QUOTE]
    Well, since I don't have air tools, I have to do it the old fashioned way.
    Current Ride
    Pearl White
    Shorty Windshield
    Previous Ride
    May 2016
    S.E. Missouri
    I was lifting each side separately and I thought the weight of the Spyder on the second wheel would allow me to loosen the lug nuts. However, after lifting one side I was not able to loosen the lug nuts on the opposite side because the tire would spin on the smooth concrete floor.
    Now, I understand it might be common knowledge to most people on this forum that you need to loosen the lugs on both sides of the bike before lifting each side of the Spyder. But I had not seen any description stating that; so I wanted to offer my experience so other newbies might have a positive experience the first time they take off their front wheels.
    Dec 2013
    I'm not saying this to have a dig at anyone specifically or even in general, but Drhunt204, on behalf of those newbies or otherwise who may not have know this about lug nuts & removing them, or even those who might've sorta known/been vaguely aware but never realised the potential it'd have for our Spyders & removing their front tires, I would like to thank you very much for risking ridicule to bring this to everyone's attention!!
    It can sometimes be difficult to share your info/experiences (or to ask for advice about something that others might think trivial) when there are people who are obviously well versed in the subject sharing their knowledge, but it always pays to remember that not everyone has the same depth of knowledge & sometimes the little things can slip thru the cracks because 'everyone' just assumes that all the readers will know them - but that's not always the case!! And besides, it never hurts to re-visit the basics every now & then, even if just to make sure that you aren't missing something that could or should be obvious... you can be very surprised by the little things that can get forgotten over time or in the stress of looking for a fix!!
    So here's a big Thank You drhunt204, not only from me for your sharing, but also on behalf of those others who might appreciate the sharing &/or the reminder!
    May 2016
    S.E. Missouri
    Default Peter, thanks for the kind words!
    I appreciate Peter's kind words. I reposted because I was concerned that a few may have been confused by my first post about how I was taking off my front tires.
    I wanted to let people know you have to loosen the lugs on both sides because of how light the front of our Spyder is compared to say a car. I thought I could break loose the lugs on the second tire while it was on the ground but the act of lifting the other side caused the opposite side to be too lightweight (or as I like to think I was just so strong and could spin the tire while it was on the concrete floor)!
