Sounds like both cables are either disconnected at the levers in the back or at the side compartments. I bet the other owner was doing some repairs and forgot to hook them back up. Nice looking bike and
I have the same problem. You probably need to push on the corresponding saddle door while pulling the lever to open it. Mine will open up at that point.
I haven't had this problem so I'm just putting this out there. Can you open the rear trunk? If you can you might try to see with a flashlight and see if you can see the cables if they are connected to the 2 rear levers. If you see the cable are connected at the 2 rear levers then they are most likely off at the side compartments. If that is the case, I'm totally lost at that point as far as getting the side compartments open. Good luck.
Since I'm new to the Spyder (had a Harley for several years), how can I access the cables?
@Ex-Rocket....Thank you!!!!
Open the rear top trunk and start removing the screws for the Tupperware. The cables will be were the top truck latch is located or just below that area.
I would try to tap/push the side cover while pulling the latch first
Hello! I recently purchased a 2014 RT S and cannot seem to get the side compartments to open. Any thoughts or suggestions??
If a push on the front of the side compartments while pulling the lever does not open it then open the trunk and with a flashlight look down each hole to see if the cable is connected. You can see it move as you pull the lever.
My left saddle bag will only open if I pull the lever then give a bump as if to close it with my hand.
I had the same issue with my 2012 RTS-SE5, I took it to the dealership, they fixed it( it was under warranty). Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
...........................But who got your helmet out of the FRUNK when the cable broke on Your IGNITION switch ? ? ?..... and was then informed to get LOST because you no longer needed my friendship ......truth is stranger than fiction
JT
I have the same problem with the left side, exact same...scary.
Brian Kay - Kennesaw, GA
2014 RT-S SM6 Pearl White (KHAOS)
TricLED 3rd and 4th Brake Lights - TricLED Turn Signals - TricLED Side Fender Lights - Airhawk R Seat Pad - Smoothspyder Belt Tensioner - JT's Dash Mount - JT's USB and 12v Power Unit - Stebel 139dB Multi Sound Horn - Lamonster NBV Highway Pegs - BRP Adjustable Wind Deflectors - Cal-Sci Stock Extra Wide Windshield - Baja Ron Sway Bar - WrapMySpyder 1330 Triple decals - Ultimate Tallboy Seat - BRP Sat Radio - ELKA Stage 2 Front Shocks
That's just being mean to Deanna, and not relevant to this thread. BTW, I have my fire suit on, so blast away!
Sometimes it's just best to keep private issues: private.
and I probably should have kept my fingers off of the keyboard.
That's just being mean to Deanna.............Actually You have that backwards ...I RESCUED HER .......She was the MEAN one ...... and not relevant to this thread....... It was RELEVANT to Her POST on this thread ........ BTW, I have my fire suit on, so blast away!
.......Not an issue, I have " empathy " for the mentally challenged .... Mike
