Page 1 of 2 12 LastLast
Results 1 to 25 of 34
    Jul 2016
    Dayton, OH
    Default Side compartments stuck - Please help!
    Hello! I recently purchased a 2014 RT S and cannot seem to get the side compartments to open. Any thoughts or suggestions??
    Sep 2014
    USA
    I am guessing you pulled on the rear levers??
    They are on cables if you did pull the levers you could remove some of the rear Tupperware to gain access to the cables.
    While pulling on the lever tap the side cover and they usually pop open.
    Feb 2013
    APOLLO,PA
    Try pushing against or putting a little inward pressure on it while you pull the release latch.
    Jul 2016
    Dayton, OH
    Yes I pulled on the two rear levers on the trunk and feel zero resistance to pop a latch for the compartments.
    Mar 2013
    Marion, Arkansas
    Sounds like both cables are either disconnected at the levers in the back or at the side compartments. I bet the other owner was doing some repairs and forgot to hook them back up. Nice looking bike and
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Jul 2016
    Dayton, OH
    Since I'm new to the Spyder (had a Harley for several years), how can I access the cables?
    @Ex-Rocket....Thank you!!!!
    Jul 2016
    Grove City, Ohio
    I have the same problem. You probably need to push on the corresponding saddle door while pulling the lever to open it. Mine will open up at that point.
    Mar 2013
    Marion, Arkansas
    I haven't had this problem so I'm just putting this out there. Can you open the rear trunk? If you can you might try to see with a flashlight and see if you can see the cables if they are connected to the 2 rear levers. If you see the cable are connected at the 2 rear levers then they are most likely off at the side compartments. If that is the case, I'm totally lost at that point as far as getting the side compartments open. Good luck.
    Sep 2014
    USA
    Quote Originally Posted by Juls1626 View Post
    Open the rear top trunk and start removing the screws for the Tupperware. The cables will be were the top truck latch is located or just below that area.
    I would try to tap/push the side cover while pulling the latch first
    Sep 2014
    USA
    I have to ask you did unlock the trunk?? I am guessing yes if you are able to open the rear trunk
    Nov 2015
    Chardon, OH
    You WILL feel zero resistance for some distance of travel. Then once you feel resistance, give it a good solid pull.
    Doug
    ”Freedom is not a loophole”
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    If a push on the front of the side compartments while pulling the lever does not open it then open the trunk and with a flashlight look down each hole to see if the cable is connected. You can see it move as you pull the lever.
    My left saddle bag will only open if I pull the lever then give a bump as if to close it with my hand.
    JT
    Banged Up Member MouthPiece's Avatar
    Dec 2009
    Sanford, Florida
    Quote Originally Posted by jthornton View Post
    JT
    What he said.
    Chris
    I also had some issues with my 2014 RT-S. I had the dealer adjust the cables and no problems since. I am not mechanically inclined.
    Vermont
    I had the same issue with my 2012 RTS-SE5, I took it to the dealership, they fixed it( it was under warranty). Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Default LOCKED OUT !!!!!!!
    ...........................But who got your helmet out of the FRUNK when the cable broke on Your IGNITION switch ? ? ?..... and was then informed to get LOST because you no longer needed my friendship ......truth is stranger than fiction
    Active Member Brian Kay's Avatar
    Jul 2014
    Kennesaw, GA (Atlanta Area)
    JT
    I have the same problem with the left side, exact same...scary.
    Brian Kay - Kennesaw, GA
    2014 RT-S SM6 Pearl White (KHAOS)
    TricLED 3rd and 4th Brake Lights - TricLED Turn Signals - TricLED Side Fender Lights - Airhawk R Seat Pad - Smoothspyder Belt Tensioner - JT's Dash Mount - JT's USB and 12v Power Unit - Stebel 139dB Multi Sound Horn - Lamonster NBV Highway Pegs - BRP Adjustable Wind Deflectors - Cal-Sci Stock Extra Wide Windshield - Baja Ron Sway Bar - WrapMySpyder 1330 Triple decals - Ultimate Tallboy Seat - BRP Sat Radio - ELKA Stage 2 Front Shocks
    Very Active Member pitzerwm's Avatar
    Nov 2014
    TriCities, WA
    I too have that on one side, I should fix it, but I just whack it and it opens.
    One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
    Nov 2013
    Central Texas
    That's just being mean to Deanna, and not relevant to this thread. BTW, I have my fire suit on, so blast away!
    Quote Originally Posted by oldguyinCT View Post
    Sometimes it's just best to keep private issues: private.
    Nov 2013
    Central Texas
    and I probably should have kept my fingers off of the keyboard.
    If we hang: we hang together!
    Mike and Dee,
    Nobody wishes either of you anything but the best...
    Sep 2014
    USA
    Well did you get the Side doors open?? Inquiring minds need to know
    Default WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAT
    That's just being mean to Deanna.............Actually You have that backwards ...I RESCUED HER .......She was the MEAN one ...... and not relevant to this thread....... It was RELEVANT to Her POST on this thread ........ BTW, I have my fire suit on, so blast away!
    .......Not an issue, I have " empathy " for the mentally challenged .... Mike
    Wow...
    Thankfully; Dee won't see it: she's got you on her ignore list...
