Results 1 to 18 of 18
    Nov 2013
    lutz, fla
    Smile 2013RT LTD Oil Usage
    My dealer says the 996cc engine should use about 1 qt every 4700 miles. Could I get a confirmation of this from other Spyder riders?
    thanks, Diggerdog
    Very Active Member rcturner's Avatar
    Jun 2012
    Fairmont, Minnesota
    My 2012 never used any measurable amount of oil between changes. I also made sure it had a proper warm up before running it hard. I am convinced that it made a difference. I have a friend with a 2012 also and his doesn't seem to use oil.
    Nov 2015
    Chardon, OH
    2000 miles through Adirondacks and Vermont. No measurable change on the dipstick. 32000 miles on the engine. Just be sure to always check the oil with the oil hot after a ride.
    Doug
    ”Freedom is not a loophole”
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    Default oil usage
    What your dealer told you is correct; I normally will use a quart between changes. I would expect 2-3 oz / 500 miles traveled. The new triples don't seem to use oil by all reports.
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Default Will vary....
    I have a RS 2012 sm5 and I don't use that much but they all do use oil. Many who will mention no use will be ryding the 2014 /15/16 1330 engines. Your dealer is right but the amounts will vary.
    ​2012 RS sm5
    Jun 2010
    Las Vegas
    I can confirm that my 2013 RT consumed a quart of oil between oil changes.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    washington state
    I don't even notice, but we must be alert on this matter coz it might bite your **** if you ignore.
    2012 Spyder RT SE5 Brake pedal mod
    Oct 2013
    rome new york
    998 use oil
    High rev
    Invalid Emails
    Oct 2015
    Deland, FL
    I use a our 1/2 quart at most between changes on my 2013 RT Ltd.
    Nov 2012
    North Las Vegas, NV
    One quart in 4600 here.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Very Active Member Bam Bam and Pebbles's Avatar
    Nov 2014
    Rural Hall NC
    My previous 2012 RT used a quart between oil changes. Of course, I rode her hard.
    Current Ride
    2015 RT-S SM6 Cocaine
    Pearl White
    Diamond R Web Armrests
    Shorty Windshield
    Previous Ride
    2012 RT SM5 The Beast
    Pure Magnesium Metallic
    Dec 2013
    My 2013 RT Ltd uses about a quart of oil every 5000 miles or so, maybe a bit less if I'm just cruising gently & the roads/weather isn't hot. It might use a tad more if I'm riding it hard in pretty hot weather or fanging it a lot, but generally a quart is at the top end of its 'between oil changes' use.
    Considering that they are an engine that uses a little oil between scheduled changes, & that only ever running these sorts of engines gently on short trips/runs will never get things warm enough to 'burn off' the accumulation of condensed water & volatile contaminants that will collect in your oil over time/use, you should probably be a little more concerned if your particular 998 Rotax doesn't actually use any oil between changes!! Maybe it'd pay you to give it a good run of at least an hour or so at a fairly good clip every now & then, or wind it out working hard thru the twisties rather than 'just poking along' reasonably often to see if you can 'burn the contaminants out' & notice the difference in oil use. After all, one of these motors that's not using a little oil between changes is probably either accumulating enough soluble contaminants in the oil to keep the oil level apparently OK, or it's just not lubricating everything properly!!
    Docdoru once posted a graph that showed a leadkdown test on a 998...
    It pointed to the fact that the Vee-Twin was gonna use oil.
    Mine would also use almost a quart between changes...
    The 1330? Not a drop of oil has had to be added to it!
    Banged Up Member MouthPiece's Avatar
    Dec 2009
    Sanford, Florida
    My "13" used anywhere from 1/2 to a full quart for every 4,700 miles.
    Chris
    May 2013
    Hackensack, MN.
    Default Oil usage
    My 2012 RT Limited uses about haif qt. between changes.Maybe a little more if I am pulling my trailer a lot.
    Active Member Richardv's Avatar
    Oct 2014
    Montreal north shore, QC
    Default Same here...
    Quote Originally Posted by Diggerdog View Post
    thanks, Diggerdog
    Samething for our 4 Spyders... and high rev and hard riding use more. Low rpm shifting also do use more....
    Richard
    Richard
    * 2012 RS SE5 (hers)
    * 2013 ST SM5 (mine)
    Daughter RSS SE5 2014
    Son in law RSS SM5 2013
    P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
    2 sets of Kumho 175/55R15 front tires
    1 set of Hankook V4
    1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
    Nov 2013
    lutz, fla
    Default Gratitude
    Thanks to all fellow Spyder riders that responded to my inquiry about oil usage on my 2013 RT LTD. I will heed all the remarks...
    Diggerdog
    Jun 2015
    Boise Idaho
    I find I use oil when pulling the trailer and not much other times
