Page 1 of 3 123 LastLast
Results 1 to 25 of 51
    Mar 2013
    Marion, Arkansas
    Default LED strips on the bumpskid
    Just curious if others are having problems with the LED's on their bumpskids. At Spyderfest 2015 I had installed a new lighted bumpskid. Well the very next day the LED's quit working or about 3/4 of them did. Went back to vendor and he put on another one. That one lasted maybe 4 months and again 3/4 of the LED's quit working. So by now the manufacture had changed to a different LED lights, so the vendor sent me a updated version that has the LED's that are now replacable. Again the LED's only lasted another 3 months or so. Vendor sent me the LED's and I installed them this time which brings me up to present. The LED's are out again with only about 1/4 of them lite up. I'm about fed up with the lighted bumpskip. Does anybody know if there is a better quality LED's that will last longer than 3 or 4 months???? I really love the looks but if I have to change this out every 3 or 4 months. Maybe I'm just snake bit. And no nothing has hit the bumpskid since the lights were working when the bike was parked last and when I got on it to ride, the LED's were out. Please help with suggestions.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Active Member nslowmotion's Avatar
    May 2015
    https://t.me/pump_upp
    Default Led
    Sounds exactly like mine, it is so agrivatng.
    Very Active Member zuni's Avatar
    Mar 2014
    JAX FL
    Sorry to hear you are having trouble. Your patience is to be commended. Haven't heard of anyone having the issues to the extent you are. Do you know the size of the led? Curious if the smaller ones are having more trouble. I did my own and the strip is with the 5050 which is a larger led. Over two years now with no issues. I ran mine in the gap above the bumpskid to give them a little protection.
    CJ JAX
    Doc Riverside has done some investigations into this... Get in touch with him, and see if he has found a long-term cure.
    Active Member Gunkandpudge's Avatar
    Nov 2011
    Hot Springs Village, Arkansas
    Default LED LIGHTS ON THE BUMPSKID
    Had mine on since last October, no problems
    file:///Users/thomasholberton/Desktop/VisitedStatesMap.jpg
    Mar 2013
    Marion, Arkansas
    Quote Originally Posted by SpongeBob2015 View Post
    At least I'm not the only one having problems.
    Active Member Gldwnger's Avatar
    Apr 2015
    Kitts Hill, Ohio
    Default cured mine
    When you replace the LED strip, Make sure you lay the bumpskid on a blacktop driveway or concrete and let it heat up in the sun. I believe the bumpskid is expanding with the engine and road heat and breaking the solder joints in the LED's. I heated my skid up to 116 degrees and then installed the new strip. Been over a year now and so far no problem. At the time I measured the skid when it was cool and after it was heated. Don't recall the actual measurments, But I think it was around 3/8 inch difference. It does expand in the heat. Hope I didn't just jinx myself. Randy
    Bryant, Arkansas
    If they are from Spyderpops ............................ why not just call him and see if he knows why yours are not working properly.
    Cruzr Joe
    Jul 2014
    St. Charles Mo.
    I'm on replacement nuber three. I get quicker on installing these. I might go to another source for led next . I've replaced one a arm strip so far also.
    May 2013
    Indiana
    Quote Originally Posted by copilot View Post
    Me 2. My Gen1 LED bumpskid went bad. Harvey replaced it @ Spyderfest 2016 with Gen 2. In 2 months, my bumpskid's LEDs would go anywhere from 100% on to 50-75% off each time I started my spyder. Harvey sent me a new, improved LED strip, which I got installed with an assist from Doc Humphries. I'll see how long this Gen 3 LED strip lasts.
    2021 Marsala Red Metallic RT Limited
    Invalid Emails
    Jul 2014
    Rotonda West,FL
    Just finished replacing my set. only 1/3 was working
    Active Member Synthetic's Avatar
    Aug 2015
    Springfield, MO
    Spyderpops lighted bumpskid is working great on mine since installation last year...
    Mar 2013
    Marion, Arkansas
    You must be trying to catch up with me.
    Mar 2013
    Marion, Arkansas
    Quote Originally Posted by zuni View Post
    CJ JAX
    I think they are 5mm LED's. I don't know if what comes with the bumpskid are 5050 or 5630 LED's. But since they are pretty bright I would think maybe they are the 5630 version. Where did you get the LED strip that you installed on your Spyder?
    Mar 2013
    Marion, Arkansas
    I sent a PM to him but haven't heard back from him as yet.
    He's probably busy in the Laboratory...
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    one of shawn smoaks videos contains a rant on aftermarket leds. does
    not like people splicing wires to install and either does the computer.--irv
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    It seems that he may have been wrong... I don't remember the exact details, but I believe that there turned out to be a completely different source, for the problem that caused the rant.
    A bit more research is in order...
    Default SPLICING WIRES ETC.
    Quote Originally Posted by Joyce47 View Post
    Whenever you tap into the OEM wiring harness you are taking a chance at UP-SETTING the NANNY ...... even if you very careful, bad things can happen........So if at all possible consider a separate fused circuit for any / all additional LED's or other types of lights that starts at the Battery.........................JMHO.............. ..........Mike
    I have had the bumpskid for over a year and 10K miles. So far, no issues with LED's. Have hit a couple things and they are still ticking after taking the licking.
    Both dealers are customer friendly IMO. I got mine from Spyderpops.
    Mar 2014
    JAX FL
    Quote Originally Posted by Ex-Rocket View Post
    I bought them off ebay. 5 5 meter roll for $12 delivered. Can't say for sure that is what is happening but the previous poster may be on to something with the thermal expansion of the bumpskip. Not sure what the coefficient is for that particular material but heat and cold can cause a fairly large change in some materials. Considering the location of the plate and the heat coming off the road.... spyders parked on the fresh asphalt at the recent Spyder Gathering in Orlando displayed temps over 120 degrees. If the led strip it tightly attached to the plate and doesn't expand at the same rate it could easily create connection issues.
    CJ JAX
    Mar 2013
    Marion, Arkansas
    Quote Originally Posted by Gldwnger View Post
    I think you are unto something here. I went out today and just turned the key on to move the Spyder some, and almost all the LED's came on except for maybe 2 or 3. Where the 2 LED's aren't working is the exact area where they weren't working before. I moved the bike to wash it and when I finished washing the bike, I turned the key back on and 2/3 of the LED's are out again. So it seems that temperature is the problem. I guess the bump skid expands when the temperature rises, as Gldwinger stated and causes the solder joints to break.
    So if this is being caused by temperature variances: how do we solve it?
    Mar 2013
    Marion, Arkansas
    Do as Gldwnger stated. Lay the bumpskid on the concrete drive, or just put the bumpskid in direct sunlight for awile and let it get hot and the bumpskid should expand and then install the LED's to the bumpskid. That way the LED's when installed on the bumpskid are at the already expanded state. So now when the bumpskid cools and heats up again, hopefully the solder joints won't break. Thats my opinion, unless someone else has a better idea.
    Thanks!
    But could that cause a problem, when it cools and contracts??
