Another tire issue
I just want to say that I have had 2 Spyder RT Limited's in the past 4 years. I had over 37,000 miles on the bike and traded in for a 2014 Ltd. I replaced the Kendra tires on the 2012 with car tires and they did OUTSTANDING. NO issue with the steering or anything. When I had very little mileage on the 14, I replace them with car tires and so far, I had zero issues.
Don't know if there is any issues with car tires vs. inferior Kendra tires, but the car tires have a 45,000 miles for the front and 40,000 for the rear tire, so, until BRP makes a better tire than what I have I will use the car tires.
Originally Posted by _..stiffler..
Why 215/60/15 and not the OEM size of 225/50/15.
I know they are close to the same height. But a bit narrow. Just wondering reason.
Sent on Note 5 in Taptalk
there are tons of threads about tires. lots of people are using this tire and is highly recommended with great results, I.E. mileage, traction, noise Etc.
Absorb what is useful, use no limitation as limitation
Awesome. Perfect thx.
I need a back tire soon. Just looming at options.
Originally Posted by Chupaca
By now I would think everyone here know of the problem they had with the Kenda in early 2014. They have since gone back to the original compound and I for one (maybe the only one) have not had a problem with them front or back. I have had two rears and two sets of fronts. I am currently on my third rear, though I want to give the Aracnid a try and it is doing well. I am now convinced that it is where (geographically) you ryde that is determining much of the wear differences...and knowing where the wear limit blocks are....jmo mind you...as for center wear, you tube drag racing and watch what happens to the rear tires... air pressure is only part of it.....
Lamonster has not had any good luck with the Arachnid tires, others have said they don't last any longer than the Kenda's.
I know, Ann (Squared Away ) also has not had great outcome. Still counting on the variables to make the difference. I had no problem with the Kenda may be the same with the Arachnid.
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
My 1st tire only lasted 4k miles BRP offered to pay for 1/2 the replacement tire. Dealer put on a Khumo for me. Khumo has slightly more road noise but does not feel as loose in the twisties.
SpyderLovers Sponsor
Originally Posted by trikermutha
How many miles on the TR1? How do the handle the cooler weather?
The Toyo TR1 gave me about 14k. The original Kenda went 11k but it had belt showing in some places so not a good comparison. I did a number of burnouts on the Toyo. I did not treat the Kenda in such harsh fashion. Plus I learned to ride the Spyder on the Kenda. I rode much harder on the Toyo.
What I am trying to say is that tire wear is relative. Some will say 'I got 15k on my Kenda so it must be as good as your Toyo'. But high mileage on a Kenda (IMHO) is more a function of where and how you ride than representative of tire quality.
My guess is (in an Apples to Apples comparison) that someone who was able to get that many miles from a Kenda would probably get 20k plus from a quality car tire if they rode it the same.
The Toyo got a bit greasy near the end of its life in cold weather. Otherwise, it was a great tire, wet, dry or cold. Problem is, they have been discontinued for quite some time. But I believe that a good quality, appropriate car tire would give you similar results.
The real reason is that you can't get this tire in the OEM size. This is as close as you can get to 225/50/15.
Originally Posted by BajaRon
...they have been discontinued for quite some time.
Ah that explains why I couldn't get one this time around, they are still on their web site so assumed they were still available. I had to go with a Toyo Proxe 4 instead which is still a lot better than a Kenda but not quite as good as the T1R for performance. Not had it long enough to see what the wear is like.
What type of car tires are you using
What make of tire would you recommend
I have heard that they are still available in other countries. Maybe that is why they are still listed.
I ran my at 24 psi and got 12,500 before I had to replace it. I recently switched to an Altimax 215/60 R43. It is a much better tire
Sent from my SM-G920V using Tapatalk
EXACTLY!!!
Typical. There is no way to keep a 2 ply tread tire from wearing in the middle. It's a given. Weak tread bands not only allow the tire to bulge in the middle when inflated. Centrifugal force at speed also acts to overwhelm the weak tread area causing a balloon effect. To me, it's a no brainer to go to a well made, less expensive car tire.
A car tire will have a 4 ply tread area. This keeps the tread flat against the road. When riding on the Kenda at speed you're only getting maybe 3" - 4" of contact. The rest of your tire is spinning in the breeze. Not a comforting thought if you have to make an emergency stop.
As you can see, I got my monies worth out of this Toyo Proxes TR1 tire (Left). Notice how much tread I put on the pavement compared to the Kenda (Right). The Toyo maintains a flatter tread area so you get nearly 100% contact with the pavement. As you can see, not so with the Kenda. The Red area is how much contact you have with the pavement at lower speeds. The Green is all you have at freeway speeds.
I know there are Kenda fans. But I wonder if they understand the full story.
Absolutely the best way to describe the condition. I sold tires for a couple years back right after highschool. My daughter currently is a tirebuilder for a MAJOR manufacturer. And you described the condition correctly. I got about 11k miles on my rear tire. Now I have 2k on my car tire replacement and no signs of wear yet.
Originally Posted by Bobleach45
28 psi is overinflated in my opinion. I had it there and dropped to 26, especially in The FL heat coupled with the heat from the exhaust. Mine was changed at 9925 miles before I bought it due to a slice in the tire . Have put on 12,500 mi and by the looks and measurement with tire tread gauge I'm anticipating getting 19-20. Can't complain about the original fronts. At 22,500 miles now and expect I will change at 27-30 and I never go all the way to the wear bars. This doesn't mean I won't try something else. That is something I'll still have to ponder. I run the fronts at 17 psi.
Smart man, yes from what I have seen many are running 25+ in the front and up to 36 on the rear - 16 or 17 is proper for the front and 24 on the rear. Wider tires normally take less pressure due to increased surface area.
Also all the suggestions regarding dumping Kenda and going with standard automotive makes sense. I ran Kenda tires on other vehicles in the past and never had much luck. Continental seems like a good brand and in most cases don't even require balancing as they tend to be nice and round and true.
Never ceases to amaze me. Everybody has a tire story and an opinion and there is no agreement what so
ever.
Kind a like trying to "Pin the Tale on the Donkey" in a dark room!
Rumor has it that a new Website called TIRELOVERS is in the works. Lamont is fine tuning it as I type.
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
But isnt it fun to give our opinion
I purchased a Kuhmo tire. Was told by dealer im taking it to, that they would install the new tire but motorcyle rims are not made for car tires! Really?
Got my Kuhmo tire on. How much air do I put in this tire. Dealer said they put in 28psi. I checked it yesterday and it only had 25 psi. I when we ride two up, we have close to 400# riding. So would 27 psi be too much?
That's what I hAve in my Kumho cold... when it warms up it gets to 30 on a hot day..
Its fun to monitor the pressure with the FOBO monitors. That big rear tire seems to flex and heat up more according to the FOBO tire monitors, it starts at 27 for me at 75 degrees and can get to 31 psi at 105 degrees on a hot afternoon. The fronts for me start at 20 psi and only climb about 1.5 psi more and only get to around 90-95 degrees. Less flexing I guess.
Quite a few run lower pressures on the Kumho and other car tires, but I just like to stick around 26-27 psi cold.. Your call, Happy Riding!!
Reason: correct
So what is the new tire in the picture. (Maker)
That is the General Altimax Tire.
I am running the General on my 2014RTS-SE6. Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
