I am looking at buying a trailer and getting some wheel chocks to stabilize the spyder. Would these locking chocks be ok from Harbor Freight? Or does someone have a better process.
I am thinking that it would be easier than using the tie down method. In the manual.
Godlover, please keep us informed on the Cabelas tie downs. I was looking at them but just didn't think they would be strong enough. I used a 4X4 bolted to the trailer floor, park front tires against it then use straps over the front tires.
But I just found a old pringle 6.5 inch wheel chock in my messy garage which the front tire will fit into. So will use it
on one tire and leave the 4X4 on the other. Have not used this system to much yet but come Sept. we are going south.
I still think I will use a rear strap thru the back tire also. Bob
Here's another option. I like it because it doesn't intrude on other things you might use your trailer for. I was going to router the 2xs so it would be flush but haven't found it necessary yet.
Where did those come from? That may be a better way to go.
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
I also use the E track in my trailer for the front wheels and use the corner tie downs for the rear wheel with an old towel to not mark the rim.Also have a motorcycle wheel chock ready in case i need to haul a bike.
Bill
minispyder dash toy
Lid lox
KradelLock
Pakitrack
SENA 20S EVO
Hi,
Just been toiling over this one for about two weeks now. Sypderclamp and Black and Gray no longer have Spyder wheel chocks. So.... I researched and thought. First of all... I don't want to squeeze my 6.5 inch tire in a locking device with possible movement from towing. Then... is it going to crunch my fender? Can I even square it up for a proper fit? Will I be able to get it out? A Spyder stands up... so I really just need it for stopping forward motion. Hey... I need to strap it anyway... right? So Spyder lovers said they just us straps.
So I decided to go with an expensive Pingel 6.5 inch ID unit... which I should get in the mail today. Revzilla had the best price and free shipping. Let me know what you decide to do friend. : )
I actually did to go Back and Gray... and I got the plastic wheel chock for the rear. It fits my 2014 STS wheel perfectly. This will stop all side to side motion of the rear tire... and I got the quick disconnect kit for it. Good luck.
Hi Bob,
Good thinking. I also got the plastic rear wheel chock from Black and Gray and quick disconnect kit. It fit my 2014 sts perfectly and will stop side to side movement. Of course I will strap as well..
Another option is Kafe wheel chocks made in California. Their expensive, but a wanted something made of aluminum. Adam Graham, the owner is a great guy and can make them any way you want. He's going to be making me a pair for my aluminum trailer.
I use the over the tire strap system I got from E-trailer.com in my 6 x12 stealth trailer. Made a couple of trips to Florida and back and the Spyder never moved.
I like those, have you tried them out and tested them?
I loaded it up and went about 25 mi. the day that I put it together. After that I used it to bring the spyder to my dealer for the recall work (about 50 mi. one way) and it did not move. I'm confident that it is good to go as it is but you could easily rig some blocking if you were worried about lateral movement. When I load it I clip the straps in so when I hit them it stops me right where I want to be. The etrack makes a nice guide to line you up as you're driving on. Easy peasy.
2015 RTS Special Series
Russell Day Long seat
F4 Customs windshield
Sena 20s
Second picture is there stock photo.
etrailer is like a candy store.
Sena 20s
Went with the track system and the straps over the tire that people were talking about. Brought the trailer home last week and the spyder was no problem. The only issue was that the ramp was a little steep but when you raise the front of the trailer it gives enough slant, so there was no scraping. The trailer also has a side ramp, that I am not really that thrilled with, but I guess I can live with it.
("It is a great day for hockey." Bob "Badger" Johnson)
