Results 1 to 6 of 6
    Active Member crochford's Avatar
    Pell City, AL
    Default What size wrench do I need
    To remove the rear axle nut off of a 2012 RT limited,, thanks
    Danbury Connecticut
    I usually like them about 5'-2" all the way up to maybe 5'-6".
    That makes it easier to hold them and guide them lightly around the dance floor.
    Smaller, and I wind up stooping down to them.
    Taller, and I'll admit it, I feel inferior.
    OOOPS silly me. I see you wanted to know about a wrench.
    I thought you said WENCH.
    My bad............................................
    IBA #47122
    2020 RT Limited Asphalt Grey
    Very Active Member garb55's Avatar
    Coolidge Arizona
    If they are real tall slow dancing has its benefits
    Now 2014 RT Limited Cognac
    Was 2008 GS SM5
    Don Garbarino
    Cup Holder
    GPS locking holder
    Mud flap
    Modified KNOTT grill
    Phone holder and charger
    Trailer hitch
    Dual air horn
    Auxiliary fuse box with relays
    Heated clothing controller
    volt/oil pressure gauge
    Sequential signals in mirror
    Tri Axis Handle bars
    Baja Ron anti sway bar/heim links
    shorty antenna
    And many more
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default 36 mm socket and Big crescent or Crowfoot open end is a good investment..
    Quote Originally Posted by crochford View Post
    I found a 1 7/16 inch crowfoot with a 1/2" drive on EBay pretty cheap.. it works well with a 1/2" drive torque wrench on the nut side while I hold backup with the 36 mm socket and 24" breaker bar.
    2015 RT , OEM Black Gloss
    36mm, and a the breaker-bar!
    Nov 2015
    Chardon, OH
    You already know it's a close fit between the nut and the muffler. No room for a socket. I find that this works well on the nut, and you can use the 36mm socket on the left side.
    https://www.powersportsplace.com/par...2585/overview/
    This also has a fitting for the torque wrench. Don't forget to adjust your torque value setting on the torque wrench to account for the increase in length if you use it.
    Doug
    ”Freedom is not a loophole”
