Air Scoops question
Where can you get the air scoops that they retrofit to the 2013 and how much are they.
Dealer
From your dealer. If you motorcycle is still under warranty they will do it for no charge even if you don't have a 2013!
Don't pay more than $67 if you have to buy them. Ride Now tried to get $150.
Does anyone know if they make them for a 2013 RS? I've seen them for an RT but couldn't find anything on an RS.
Will they fit the 15 RT-S
Sure
But they should not be necessary on the '15.
And I doubt you would get them for free for a 14, 15 or 16.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Yes and the cost is @ $80.00
AJ
2014 RT-S
Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
So... I have a 2011 RTS would my dealer put them on mine got little to no cost?
Sent from my SM-N920R4 using Tapatalk
Ok not finding how to install these scoops on my 15 RT-S. Some of the older models have to remove some inside parts and add a stabilizer bar. I find pics of 14-15's but do not say how they installed them. Is there a video or instructions somewhere. Thanks.
Search the forum for Doc Riverside, his post will give you all the information you need. Some people say you don't need them on the 2015's and that may be true, but I can honestly say, that on the hot 100+ degree days here in Florida, my 2015 RT Limited is much more comfortable, and the glove compartment much more useable do to the lack of heat in that area.
David
How old would you be if you didn't know how old you were?
The RS 2014+ body panels have air scoops built in. These can be retro-fitted to 2013's and earlier models.
Lamont did publish the part numbers a while back but I can't find the post for you. I believe there where three panels that have to be replaced, the top side panels that have Can-am written on them and the top Y shaped panel.
Someone on the original thread said they had paid around US$270 for the replacements but again can't find the post.
Hopefully someone who's already made the change will be able to give you more info.
Thanks!! You would think they could just make the scoop so it would fasten to existing panels and you could just cut a hole or even just drill a series of holes.
