One way valve for 2012 Can Am Spyder RT Ltd
I recently had to replace the left hand side headlight, but in the process, I found a loose part. It appears to be for the fuel system, but I haven't been able to find where it is supposed to be installed. It's a rubber fitting, about 1 inch tall, and has a 90 degree bend leading to a 2 inch one way valve which is beveled at a 45 degree angle. it has a small filter inside. I have poured through the online documentation, and searched every parts diagram available, but I just can't figure it out. I can send pics if needed.
Pictures go a long way in identifying parts. Hint hint
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Don't recall anything such as that in the fuel system or intake system, and I've been pretty close to both. If you're not the original owner, it may not even go on the machine. You can post pictures right here on the forum. Check the FAQs for directions on how to upload attachments.
Doug
”Freedom is not a loophole”
Rubber
This goes on the back of the headlamp assembly. It must of fallen off when you where reinstalling the headlamp.
Thanks. Yeah, I was just now thinking the same thing.
Doug
Sorry about the pics, or lack thereof
Thank you for all of your help in advance
Thank you for all your help
Hey All, Thank you for all your help, it is indeed a rubber vent for the back of the headlight lens. Part # 219800133, "Rubber Ventilation" according to BRP.
