Results 1 to 13 of 13
Thread: Motorcycle Lift
    Active Member SteveandBelinda's Avatar
    Jun 2016
    Canton, MI
    Default Motorcycle Lift
    Does anyone have, or use one of the Harbor Freight motorcycle lifts. If so, how well does it work, and safely? Good price at $89,00 plus your 20% off coupon .20160709_111309.jpg
    2014 Can Am Spyder RT Limited - Pearl White
    2010 Can Am Spyder RT - Full Moon
    Pragmatic Member Pampurrs's Avatar
    Mar 2015
    San Tan Valley, AZ
    I have one and use it all the time. I'm using it right now as a matter of fact
    Pam
    • 2015 RT-S Special Series / Red & Black
    • Baja Ron Sway Bar
    • Utopia Backrest
    • F4 Customs tall and wide vented windshield
    • Stebel Super Loud Air Horn
    • Baker Built Air Wings
    • LaMonster Highway Pegs
    • SpyderPops Exhaust Block Off Plate
    • SpyderPops KOTT Grill
    • SpyderPops Belt Guard
    • Cat Bypass
    • Laser Alignment by Squared Away
    • TricLED Fender Lights
    • General Altimax RT43 rear tire
    • Dual flag holder
    • Mud Flap
    • A$$hole seeking missile system
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Default Works Well
    I have the one you showed in your OP from Harbor Frieght. It works very well. For an RT, you slide it under the side right at the floorboard area. It will catch the bottom frame rail there with both forks. Be sure to further secure the bike with lift jacks if you are intending to work underneath it.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by robmorg View Post
    That't the exact same one I have, just a different color
    Pam
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default WORKS GR8
    I ALSO USE MINE ON MY JOHN DEERE TRACTOR....
    IT TUCKS AWAY NICELY UNDER MY WORK-BENCH....
    SPYD3R
    Active Member WEB-WVR's Avatar
    Sep 2009
    Albany, Oregon
    I have that blue one to the left of the one you photographed. The blue one (also comes in yellow) is heavy duty and many of us are using it.
    Craig From Albany Oregon
    Sep 2009
    Albany, Oregon
    Same jack but in yellow. Harbor freight has the blue ones. They did use my 20% off coupon on this jack !
    I noticed you have an RT...I WOULD USE THIS ONE...it is rated for heavier weight.
    Registered Users sypderrobinson134's Avatar
    Jun 2014
    St. James, Mo
    I've Been looking into this it seems as if most of you prefer a standard motorcycle jack over one of the spyder lifts that I was looking at a few days ago is that true?
    Default It's the Jag....
    Quote Originally Posted by WEB-WVR View Post
    The yellow one in the picture is a craftsman I think they use yellow and harbor freight uses blue but they are the same. I bet I if snap-on sold them they would be red.....and a bit more pricey..
    ​2012 RS sm5
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    I use a J&S jack. They are much more expensve but withe the spyder adapter, the bike is VERY secure in the up position. You can spin the spyder and roll it where ever you want. You do not need the other supports such as jack stands or rear wheel support
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Jun 2016
    Alexandria, VA
    Don't have my Spyder.... yet. I wonder how well this would work? http://www.ragepowersports.com/motor...ducts/mc-jack/ I bought it for cleaning bike wheels. Lift one end at a time and place on ramps or jack stand(s). Maybe I should just go to Harbor Freight and buy the ATV Lift? The "Rage" needs about 6" to get under the frame.
    Default THE RAGE
    Quote Originally Posted by Conaso View Post
    Well I read the spec / info sheet ....and I wouldn't use it for many reasons........Mike
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by sypderrobinson134 View Post
    I already had my Harbor Freight motorcycle lift for my previous motorcycles when I switched to the Spyder. If I was buying one today, I might look at some other options. But the one I have works fine.
    Pam
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
