Results 1 to 6 of 6
Thread: Bad ball joint?
    Active Member Stumpy6Guns's Avatar
    May 2016
    Valley Center, CA
    Default Bad ball joint?
    I think I have a bad ball joint on the left side of my '12 RTL. I've been griping and complaining on the RT Touring forum about my bike's squirrely handling, and today coming back from lunch it starting shimmying really bad in a left-hand turn. Scared the hoo-haw out of me.
    Anyways, the right wheel doesn't have any play, but the left wheel will rock back and forth when I push/pull on the top of the tire. I just called for a tow to the dealer (yay for AAA motorcycle coverage!); we'll see what's up.
    Myron Wooley
    USMC 1975 - 1979
    2nd Spyder: Pearl White 2016 Spyder RT Limited, purchased December 18, 2016 with 1 mile
    First Spyder: Pearl White 2012 Spyder RT Limited, gone to a good home
    2010 RTS-SE, Orbital Blue
    Sep 2009
    illinois
    Possibility of a bad wheel bearing.
    Dec 2013
    Watch carefully when you are pushing/ pulling on the top of the tire, cos if the entire 'A' arm is moving as you rock, it's more likely to be the chassis end 'A' arm 'pillows' & bushes that need replacing!! The 'A' arm won't move with the tire as you rock it back & fort if it's the ball joint that's worn; in fact, if you wrap one hand over/around the ball joint & rock the tire with your other hand, you should probably feel the movement & possibly grinding inside the ball joint as you rock!! You won't feel that if the 'A' arm bushes or the wheel bearing/s are the issue & the bushes are a helluva lot smaller & more prone to 'early damage or wear ' than most ball joints or wheel bearings that haven't taken a really hard knock!! You haven't hit a kerb HARD lately have you?? Run that wheel into a car or big pot hole at speed, or something like that have you?? Regardless, it's all good stuff to check out when you have a wobbly wheel!
    Good Luck getting it sorted!
    May 2016
    Valley Center, CA
    Default Down for at least a week
    I had it towed to the dealer. They're going to check it out and fix it. The air scoop kit is going on as well.
    Myron Wooley
    USMC 1975 - 1979
    We're waiting to see how your bike handles, after the Dealer gives it back to you!
    Sep 2012
    Junction City, KS, USA
    Me, too. I think he should just trade it in on that '16 he got to try out.
    PrairieSpyder (Patti)
