Results 1 to 6 of 6
    Very Active Member btcherm's Avatar
    Howard City, Michigan
    Default easy quick fix for hot foot on the right side on rts
    here is a easy fix I came up with I use this IMG_5194.jpgIMG_5200.jpgIMG_5199.jpg\
    IMG_5201.jpg you cab buy this from tandy leather...I use a 11/4" hole saw and a 3/8 drill, formed with hot air gun
    then when hot put cover back on...
    Default Nicely done...
    Are you removing the lower panel to allow the air out the bottom..?? Help get it out of there and keep engine compartment cooler...
    Bryant, Arkansas
    if you are not letting that heat escape somewhere ................................ something other than your foot is gonna be very hot
    Cruzr Joe
    IMG_5205.jpgthe hot air now come more out the bottom hole and under my floorboard
    Nov 2013
    Central Texas
    Tandy Leather still exists? Haven't heard that name in probably 20 years.
    I do a lot of leather work, and I buy my leather from them,here in Michigan.
