LED Fog Rings anyone?
I've seen the LED fog ring sets from TRICLED and also Lamonster and I'm wondering if anyone here has installed them on their F3?
It says when placing the fog rings on the cap where the fog lights would normally go, to notch out the corner for the wire to feed through and to use the dielectric grease on the electrical fittings/connections.
Anyone installed these yet?
Any insights or thoughts about the amount of light these rings put out?
Any advantages to using the bullet wire connectors versus the lever lock connectors? Your opinion?
Please share your Pro's and Con's.
Thank you in advance for sharing!!!
HAND'S UP:
The only sure way of getting rid of bad habits is to create good ones.
AND, by the way, this will not happen on auto pilot.
It's time for a YOU-turn!!!
I installed them over my OEM fog lights. Reggy told me I'm the first person he's encountered that has OEM fog lights. Does anyone else have them?
Anyway, the "standard" install wouldn't be quite the same in my application. I'll let others answer about that. I also have the LED Cyclops light from Spyder Pops, so I ended up tying in the connection for the LED rings into the cyclops connection which had the lever action connector -- it was easy to add the new wires into it.
We now have His and Hers Spyders!
Current Spyder: White 2015 F3-S SE6
His Spyder: White 2015 F3 SE6
Previous Spyder: 2012 RT Limited SE5 -- 30,300 miles
Previous rides: Kawasaki & Honda
I just installed in Lamonster fog rings yesterday and I'm petty impressed with out come. I posted a few pics under the heading Fog Rings add bling.
Life is GOOD...............
2015 F3S
SmoothSpyder backrest
lidloxs
Gloryder F3 Logo Lights
Lamonster mirror relocations and turn signals
Lamonster fog light kit
Lamonster Power Plate
X Grip
Ram mount
OK. Thanks! I'm including the link below:
http://www.spyderlovers.com/forums/s...ht=rings+bling
HAND'S UP:
The Lamonster install took less than 30 minutes and so far the lever lock system is what I prefer.
2015 F3S
lidloxs
X Grip
Ram mount
I've not been able to find the lever lock wire connectors anywhere here locally. WHERE DOES ONE FIND THEM???
HAND'S UP:
I just bought 50 off Ebay delivered for $6.50 US but remember they are not water proof
Can you please inbox me the EBay seller or the link to the item you purchased. Thanks for your reply and help!!!
HAND'S UP:
Try this link
http://www.ebay.com.au/itm/162007529...%3AMEBIDX%3AIT
Originally Posted by BLUEKNIGHT911
THE exact SAME ITEM IS AVAILABLE FOR 1/2 PRICE W/FREE shipping item # 291644604445 on the US E-bay site .....Mike ...................................or other styles / amounts from same seller
Thanks Mike. I placed the order for 20 for under $7 shipped.
HAND'S UP:
HAND'S UP:
HAND'S UP:
Unfortunately, I am unable to say the same thing for the Fog Ring kit I just installed on my F3 from another seller.
HAND'S UP:
I like the look... May go this way!
Live, Love, and Ride! God Bless!
We are loving ours.
HAND'S UP:
A word of caution on those connectors.
In my batch of 20 units 6 were not electrically conductive.
The negative wire was mis-soldered on them and didn't conduct juice.
The wire end was held on to the connector pin with melted wire insulation.
The Power of Logic.
Start Thinking.
The ones from china are cheap copies of the real wago connectors.
You will be lucky if half of them actually work when you receive them in 6 weeks from china.
Buy the real ones from Newark or other electrical supply and save your self a bunch of trouble.
Has your claim been verified?
HAND'S UP:
Yes, first hand. they are cheap chinese copies of the real german Wago connectors. Phoenix Connector also makes a similar connector here in the US.
2015 F3 SE6 Black and Chrome, Smoothspyder Backrest and more to come.
Where do you get'em?
HAND'S UP:
Newark
