Results 1 to 4 of 4
    Apr 2015
    Grand Forks, ND
    Default Hose Throttle Cracked?
    If the 2 hoses to the throttle body are cracked and it's running ruff will this show up on buds?
    Mine is a 2012 RTS it runs ruff and check engine light is on. It's at the dealer now.
    Jim
    Default BUDS - LINK
    BUDS is the link to the Spyders computer files (?).....IMO, anything that occurs in the spyders system is logged into the computer and can be retrieved.................Mike
    Default Agree...
    but buds will not detect it if no codes are being thrown. ..the tech would be the one to find it and should be well aware of the problem. Hopefully they will replace them with silicone hoses and not the oem ones...you can hope but should supply your own. ..
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    If the hoses are cracked, it should show up as a lean mixture on BUDS.
    john
