Results 1 to 18 of 18
    Mar 2012
    Spokane, WA
    Default 9,000 mile oil change and service
    Just took my 2015 RTL to dealer for oil change, my oil, and recommended 9000 service. I was told that it was 4 hrs to do this. This seems excessive to me and I was just wondering if this is in line with others that have the 1330. I also need a new rear tire and was told that was 2 1/2 hrs to replace. Not complaining about tire life, 9700 miles, but again 2.5 hrs seems a lot. Just wanted to get your input about your experience with your dealership. Thx in advance for input.
    2015 RTSE, Red Pearl, Shorty Antenna, Chrome Rear Rack, Deer Whistles, BajaRon Anti-sway Bar
    Very Active Member pitzerwm's Avatar
    Nov 2014
    TriCities, WA
    Better get use to it or start learning how to do your own work. You are at their mercy just leave a blank check. Don't you have a couple dealers up there? We only have Ride Now, many take their bike to Vancouver, ProCalber.
    If you have an extended warranty, you either have them do it or document really well that you are doing it. Look here for other options on a rear tire, unless you want only 9700 which is good, for that OEM tire, on the next one.
    One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
    Mar 2012
    Spokane, WA
    Yes have 3 dealerships. Got the Spyder at this dealership. Had the 3000 mi service and was very reasonable. Had a tire changed on my 13 about 11 - 12 months ago, different service manager, and was only charged an hour. Should have done my price checking before I left the byke. But I was still courious as to the hours other are being quoted.
    Apr 2015
    Oregon/arizona
    Default 9000 miles service
    Quote Originally Posted by Showie View Post
    Seriously doubt you will get a better price at pro caliber in Vancouver. However, they have a good reputation. I've not used them for service. Was quoted 480.00 for 3000 mile service so used someone else. However, for a regular oil change they might have a better price. A bit far from Spokane. As the other poster said, we pay or do it ourselves. I think many on the forum who do their own are spending at least four hours. Like anything else, the more you do,the easier and faster one becomes. Personally, I would rather be fishing/ reading/ kayaking ect. Doing the change yourself allows you check your trike and you know everything was done right. Damn, I love retirement. Best of luck.
    Pete
    Nov 2014
    TriCities, WA
    Nothing says you can't get prices from the other 2 and question this one, for the differences. I wouldn't let it just go, unless you carry KY with you. At least ask for a kiss.
    Jun 2010
    Las Vegas
    2 1/2 hours to change the rear tire is excessive.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Active Member WellsboroSpyder's Avatar
    Feb 2014
    Wellsboro, PA
    Default 10,000
    Our 2015 RT-s just hit 10'000. Tire is still good. Wonder if the center of your tire is worn and not the edges? Our 2013 rear tire wore out in the center at 8,000 useing old dealers recommend air pressure. Kurtz Motorsports is our new dealer . Has us running 23 pounds in the rear. Wearing evenly.
    Traded 2013 rt s se5 for pearl white 2015 RTS se6 .
    Gloryder hubs
    622 trailer
    bumpskid
    Wife and I have been a couple since 1980
    32 years of wedded bliss
    Nov 2012
    North Las Vegas, NV
    Some dealers claim 2 hours plus for an oil change. For an experienced tech this is a little long.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jul 2014
    Mint Hill, NC
    A question that may save some time on the apparent upcoming ox goring. You say 9,000 mile oil change. Do you mean 9,000 total miles on your odometer or 9,000 miles since the 3,000 mile oil change? If the former, you still have 3,300 miles before the oil change is due (pg. 120 of your operator's guide).
    I agree with SpyderAnn on the price for the tire change alone. Does the 2 1/2 hours include a lunch break for the tech?
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Default WASTED TIME
    ....... sounds like Vultures , adding the time to go out and find the " road kill " for lunch
    My dealer charges for an hour's worth of labor: for either of those two chores.
    Active Member rpatsh's Avatar
    Sep 2012
    Spokane, WA
    Hi Showie,
    I take mine to Allsport, I usually just drop it off and come back the next day to pick it up. but I've been realy happy with the service I've gotten from them.
    2015 F3s White
    BRP Drivers and Passenger backrest
    Blue Ridge windshield
    Corbin Saddle Bags
    Active Member cyclekid58's Avatar
    Sep 2014
    Post Falls Idaho
    Default 9000 Mile Service
    Showie
    I was only charged 2.5 hrs for both the service and rear tire change at the same time at the CDA dealer, now that he moved to allsport I will probably look into costs there and compare.
    Greetings from Idaho
    2014 RT-S,
    Barjaron swaybar, chome luggage rack, Ram Mount GPS, 12 volt dash outlet, spyderflap mudflap, Rivco flag mounts, drink2go and custom handlebar drink holders,Driver Backrest,Tri-Axis Handlebars, TRICLed turn signal lights. Custon Dynamic Magic Strobe Brake Modulator, Triple Dash Pouches, "Squared Away" Laser Alignment, Spyderpops Bumpskid, TricLed "Knightrider" LED
    2014 RT , White (Mine) Cognac (wifes)
    Mar 2012
    Spokane, WA
    Quote Originally Posted by WellsboroSpyder View Post
    The wear is probably on me. Put 7,000 miles on end of May and 1st of June. Charleston, SC and back. Had wife and pulled a trailer for about 1/2. Heat was high and I should have lowered rear pressure. Checked pressure in morning and all tires were good on FOBO. Once on the road in the heat I found out the rear tires would heat up 5+ degrees. Learned a lesson and a word to the wise check tires after about 1/2 an hour out on the road. Quite easy with FOBO or the alarm will sound if you keep bluetooth connected and in hearing range.
    Mar 2012
    Spokane, WA
    I know but put 7,000 hot miles during trip to SC and I needed a new rear tire anyways. More convienent to get both at same time, less down time.
    Invalid Emails murphybrown's Avatar
    May 2010
    Chelan, WA .. the dry side!!
    Default OUCH
    Excessive on all counts. IMHO....glad you had a wonderful trip..
    My Motto Is:
    Live my life in such a way that when my feet hit the floor in the morning...Satan shudders & says "Oh, crap, SHE'S awake!"
    Red Stallion: 2016 F3t SE6 (from Pitbull PowerSports/ Springfield, MO)
    White Knight: 2014 RTS SE6 and matching 622 trailer (from Pitbull
    Ms Spydee: 2010 RT SE5
    Pragmatic Member Pampurrs's Avatar
    Mar 2015
    San Tan Valley, AZ
    assuming you had the oil changed at 3,000, your next oil change should be at 12,300.
    The tire change should be ONE hour labor. Same with the oil change, however, the 9,300 mile service does include some additional inspections and minor services.
    This why so many of us perform our own services.
    Pam
    • 2015 RT-S Special Series / Red & Black
    • Baja Ron Sway Bar
    • Utopia Backrest
    • F4 Customs tall and wide vented windshield
    • Stebel Super Loud Air Horn
    • Baker Built Air Wings
    • LaMonster Highway Pegs
    • SpyderPops Exhaust Block Off Plate
    • SpyderPops KOTT Grill
    • SpyderPops Belt Guard
    • Cat Bypass
    • Laser Alignment by Squared Away
    • TricLED Fender Lights
    • General Altimax RT43 rear tire
    • Dual flag holder
    • Mud Flap
    • A$$hole seeking missile system
    Active Member Markg's Avatar
    Sep 2015
    St Joseph, Il
    Default 9300 service
    I just had my 9300 mile service done for $260. It is a 2 1/2 hour job. I also thought it was excessive, before I had the service done. It is more than an oil change & I took the advice I had seen here. I looked at the owners manuel & saw there was quite a bit more to this service. I could probably do most of it but my dealer did all all of it, correctly, on the first attempt.
