Results 1 to 13 of 13
Thread: Spyder RT cover
    Sep 2015
    Grovetown Georgia
    Default Spyder RT cover
    I am thinking about buying a Show Chrome rear luggage rack for my 2014 Spyder RT limited. I know my BRP half cover will not fit over the rack. Will the BRP full cover fit over the rack? I use the half cover frequently so does anyone know an aftermarket one that fits over the rack? I don't use the full cover much but it seems the BRP might work as there is some slack around the trunk door. Thanks!
    Sorry...
    There's not a bit of slack, and the BRP full cover will also no longer fit.
    Nov 2013
    Central Texas
    I have a Show Chrome rack and this is the cover that I use. It fits perfectly over the rack. Good price, too.
    http://www.bigbikeparts.com/template...GroupGuid=2016
    Very Active Member mrfats's Avatar
    Jul 2011
    Morgantown, WV
    I have a trunk rack from diamondraccessories.com and the half cover fits over it.
    John,
    As I recall: there's a little bit more slack in the fit of the half-cover; right?
    Nov 2013
    Central Texas
    John,
    Bob, after I put the rack on, my half cover would no longer fit, as it did not have enough stretch to get over the rack. I had heard that the BRP full cover also would not fit, so I ended up getting the full cover from Big Bike Parts, which is bigger than the BRP cover. And, at $94.90 with shipping, a better deal than the BRP cover.
    Northern Kalifornia
    Default I have both covers
    One large Tourmaster is the full cover and a BRP half cover. Neither one fit after I installed my trunk rack. I took both covers to a skilled custom upholstery shop and had expanded panels installed in each cover to accommodate the trunk rack. I supplied the material and the cost to modify the two covers was $50.
    Idaho
    Quote Originally Posted by oldguyinCT View Post
    However, just for info, the pocket on that cover is too small to fit over an F4 tall and wide windshield. I had one. Switched to a Guardian cover which fits over the windshield quite nicely. I think it would probably go over a trunk rack also.
    2014 Copper RTS
    Jan 2015
    southern WI
    I have the rack on our RT as well, and I use a full cover, UltraGuard. Works great! AND cheaper than a BRP cover.
    2021 RT Limited
    2016 RTS , Pearl White
    Bryant, Arkansas
    Quote Originally Posted by Mazo EMS2 View Post
    Ultra Guard 1/2 or full cover will work with a larger windshield or rack and probably both and 1/4th the price of a BRP cover.
    Cruzr Joe
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by dwainjohnson View Post
    I have that rack and the Ultraguard from Value Accessories works very well. and is a good buy for the quality of cover you get. Nothing from BRG will work once you put the ShowChrome rack on your trunk.
    Now as to that rack, I have had it for a year and if I didn't have the holes drilled in the trunk lid I would take it off and find something that gave me a level platform. Or learn to do without one. You can't put that much weight on it anyway and I no longer like the looks of it ,but there are those holes
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Very Active Member DR Buck's Avatar
    Apr 2012
    Fauquier County VA - Virginia's most carefully pronounced county.
    Default My solution
    This link is to a thread I did on the same problem several years ago.
    http://www.spyderlovers.com/forums/s...l=1#post659314
    2012 RT Limited - Pearl White
    My Mods -
    http://www.spyderlovers.com/forums/showthread.php?39494-DR-Buck-s-2012-RT-Limited-Mods
    2012 RT Limited , Full size brake peddel White w/Red Highlights
    Very Active Member dlby's Avatar
    Nov 2014
    Indiana
    Ultra guard is on our rts.e6
    With a luggage rack and a suitcase on top of that
    Great cover
    And some say it's not rain proof but I have never had a drop get through
    Sent from my SAMSUNG-SM-T337A using Tapatalk
