Spyder RT cover
I am thinking about buying a Show Chrome rear luggage rack for my 2014 Spyder RT limited. I know my BRP half cover will not fit over the rack. Will the BRP full cover fit over the rack? I use the half cover frequently so does anyone know an aftermarket one that fits over the rack? I don't use the full cover much but it seems the BRP might work as there is some slack around the trunk door. Thanks!
Sorry...
There's not a bit of slack, and the BRP full cover will also no longer fit.
I have a Show Chrome rack and this is the cover that I use. It fits perfectly over the rack. Good price, too.
http://www.bigbikeparts.com/template...GroupGuid=2016
I have a trunk rack from diamondraccessories.com and the half cover fits over it.
John,
As I recall: there's a little bit more slack in the fit of the half-cover; right?
John,
Bob, after I put the rack on, my half cover would no longer fit, as it did not have enough stretch to get over the rack. I had heard that the BRP full cover also would not fit, so I ended up getting the full cover from Big Bike Parts, which is bigger than the BRP cover. And, at $94.90 with shipping, a better deal than the BRP cover.
I have both covers
One large Tourmaster is the full cover and a BRP half cover. Neither one fit after I installed my trunk rack. I took both covers to a skilled custom upholstery shop and had expanded panels installed in each cover to accommodate the trunk rack. I supplied the material and the cost to modify the two covers was $50.
Originally Posted by oldguyinCT
However, just for info, the pocket on that cover is too small to fit over an F4 tall and wide windshield. I had one. Switched to a Guardian cover which fits over the windshield quite nicely. I think it would probably go over a trunk rack also.
I have the rack on our RT as well, and I use a full cover, UltraGuard. Works great! AND cheaper than a BRP cover.
Ultra Guard 1/2 or full cover will work with a larger windshield or rack and probably both and 1/4th the price of a BRP cover.
Cruzr Joe
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
My solution
This link is to a thread I did on the same problem several years ago.
http://www.spyderlovers.com/forums/s...l=1#post659314
Ultra guard is on our rts.e6
With a luggage rack and a suitcase on top of that
Great cover
And some say it's not rain proof but I have never had a drop get through
Sent from my SAMSUNG-SM-T337A using Tapatalk
