We now have the Spyder RT Rear LED Saddlebag Run/Brake/Turn available.
We installed a pair on our own RT. These are incredibly bright. The nicest feature is the dual color going to very bright Amber for Turn Signals.
These Saddlebag LED's are one of the easiest solutions to adding a Run / Brake plus Amber Turn Signal all in one.
A Flashing Yellow at the outer edge is the absolute best way to signal and be seen.
One of the best features is when it is off all you see is the patent pending Black Tube that will not detract from the look of your RT.
Installed on the vertical sections of the rear of your saddlebags below the rear lights.
The Nano Arc Circuitry is Super Bright and even more amazing is that they turn from Red To Amber when using your turn signals.
The LED's turns on with your running lights and glows to a brighter intensity when brakes are applied.
We have these installed on our own Spyder RT. Gives the bike a whole new look from the rear.
This design allows for an easy no drilling install using new OEM style connectors.
Simply PLUG into the factory harness and make the connections, there is no drilling, cutting or posi-tap needed!
Torx Screwdriver needed for installation. This is a fairly easy installation. Instructions are included.
You will need to DROP down your rear Black Plastic trim for access to your Rear Light Connectors.
