Results 1 to 23 of 23
    Houston
    Default Pleading request for SpyderCodes
    SpyderCodes
    I use your app on a Samsung Galaxy S7. Its an indispensable tool for me and much appreciated but I just HAVE to ask. No, BEG is more the right term, for you to get RID of the combo lock style picker and just let me type in a code. I spend LONG times trying to get the digits to line up just so before the app will look up the code I need.
    PLEASE can you fix this?
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Default Just a note...
    you don't have to line them up just click on them when you see them and they will appear on the lookup code. Still not what you want but will save you time till there is a change....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Very Active Member spyderCodes's Avatar
    Jan 2016
    PA
    SpyderCodes
    Yes, as Chubaca said it isn't that bad.
    Well maybe it is.
    I've noticed that on some platforms it works as I had intended and on others I can't figure out how to use the damn thing.
    Yes. it can be fixed (obviously) but you'll have to cut me some slack for a bit.
    There is a major upgrade in the works for the Apple & Android.
    This is a particularly busy time on the farm, but I will make this a priority.
    Promise.
    Houston
    Thank you Thank you Thank you!
    Nov 2013
    Central Texas
    Yes, thank you Roger!!
    Pragmatic Member Pampurrs's Avatar
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by spyderCodes View Post
    Well maybe it is.
    Promise.
    I've never been able to get this app to look up codes on my Samsung Galaxy. I'm looking forward to your upgrade. For now it's just a dormant app taking up space on my device.
    Thank you for creating this app
    Pam
    • 2015 RT-S Special Series / Red & Black
    • Baja Ron Sway Bar
    • Utopia Backrest
    • F4 Customs tall and wide vented windshield
    • Stebel Super Loud Air Horn
    • Baker Built Air Wings
    • LaMonster Highway Pegs
    • SpyderPops Exhaust Block Off Plate
    • SpyderPops KOTT Grill
    • SpyderPops Belt Guard
    • Cat Bypass
    • Laser Alignment by Squared Away
    • TricLED Fender Lights
    • General Altimax RT43 rear tire
    • Dual flag holder
    • Mud Flap
    • A$$hole seeking missile system
    Jan 2016
    PA
    Quote Originally Posted by Pampurrs View Post
    Pam
    Kindly read the info under the "How to use Picker" button.
    That might shed some light
    Mar 2015
    San Tan Valley, AZ
    I have, many times
    Pam
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    Jan 2016
    PA
    I have, many times
    Pam
    Okay.
    as I said I will change it.
    Do me a favor.
    Click in B1000 and see what comes up.
    Mar 2015
    San Tan Valley, AZ
    Okay.
    Do me a favor.
    I think I just figured it out. I was scrolling the combo lock wheel. I guess that doesn't work. Thanks
    It would be nice to be able to just type the code though. It's a very handy app in any case. Thanks for creating it.
    Pam
    Like
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    Jan 2016
    PA
    It was developed on a Galaxy 7 tablet.
    It really does work but typing it in will be easier.
    May 2013
    Edmonton Alberta, Canada
    Pam
    Works great on my Samsung Galaxy.
    2014 RT-Ltd , Cognac
    Jan 2016
    PA
    OK, changing the Picker for the codes is going to happen but I can't help but think that I didn't make the instructions clear so if you are having trouble please read the following and give it try.
    1. The picker does not require you to line up the numbers perfectly. It will do that for you.
    2. Scroll to P, once P is more or less in the center, TAP it just above the YELLOW line in the column you are using.
    3.Scroll to 1, again just get it close and then TAP the center. The 1 will lock into place
    4. Likewise do this for 6, 1 & 0
    5. P1610 should be written just below the word Picker.
    Please try it.
    Bossier LoUiSiAna
    Thank you for NOT giving the default "Is the app up to date?" response that every other app out there does
    Mar 2016
    Northern New Jersey
    Thanks for the clarification. I never would have figured it out by myself.
    Great app. Thank you. Thank God I haven't needed to check any codes yet
    Houston
    Please try it.
    Those are much more clear and do seem to work. Rally would like to be able to just type it in though. Thanks Roger, the app is very useful to me.
    Jan 2016
    PA
    I am glad it works for you.
    I will make it a choice between typing or choosing in the next edition but the fact that it actually does work is good to know.
    There are always different ways to do anything.
    Active Member Minister's Avatar
    Apr 2011
    Paragould, Ar
    Default IPhone
    I don't know if you have done updates or not, but the app works good on my iPhone. Thanks!
    To God Be The Glory!
    Very Active Member Dan McNally's Avatar
    Jun 2013
    I must have stumbled on the "tap" to get the code by accident - I have always done it that way since you changed to the combo lock method. It works great on my Samsung Galaxy Note 4
    Thanks for all your work on this, Roger. My daughter's boyfriend writes Apple apps and I see the amount of work involved.
    "Topper" is my Pearl White 2013 RT-LTD
    Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
    Happy to be a member of the Maryland Spyder Web - find us at
    http://www.meetup.com/MarylandSpyderWeb/
    Jan 2016
    PA
    The app update will be in September.
    Registered Users Gray Ghost's Avatar
    Harper, Texas
    Thanks for all your dedication in keeping this app available for us.
    Clifford Fargason
    2013 Spyder RTL
    2007 Royal Star Venture
    Jan 2016
    PA
    Well, if I didn't enjoy it I wouldn't do it.
    A year or so ago during a fuel stop on the PA Turnpike this happened.
    Another Soyder was opposite me.
    He got off and fueled up.
    Then he took his phone out and apparently entered the mileage.
    We nodded and he said "Do you know about this app called spyderCodes?"
    I said, quite honestly, "I don't have a smart phone."
    He said "You ought to get one, it's really worth it."
    That kind of thing makes it all worth it to me.
    Jun 2017
    Independence, MO
    Default Amazing 'app'
    I'm a relatively new ryder and did not know about this app until this evening!
    THANK YOU SO MUCH for your work on this - it seems VERY useful and one of those apps that I will USE!!
    Chris Kovachevich, CDS
    Independence, MO
    HOG # US5032392
    BCA #47866
    Growing old is mandatory; growing UP is optional!
