Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
  1. #26
    Feb 2016
    Usa
    Quote Originally Posted by kaamacat View Post
    I picked up a few different ones from BandC on Amazon.
    Under the seat installed a regular style for a possibly air pump. On the left of center on the
    dash (meant for either the heated grips or aux light, forget which), put a BandC dual USB
    into that one. Super clean to install there. You do have to make the hold a tad larger for the
    BandC to fit. (But I figure cost vs cost, going into the left side panel is more expensive to
    replace for someone that does not like it there)
    Is it plug and play or you need install fuse?
    thanks
  2. #27
    Feb 2016
    Usa
    Quote Originally Posted by Retired 2012 View Post
    I remember seeing post where someone drilled a hole through the left side service panel and put a plug there, any one have any regrets about doing that
    pros and cons
    Do you have pictures ? I want go in the same way but I can see how look before thanks
